ABS not kicking in
10 replies to this topic
#1 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 08 January 2014 - 01:38 AM
Correct me if I'm wrong but with ABS I should never really be able to lock up the brakes, or I should at least hear it buzzing. I looked just behind the passenger side light and saw the ABS unit under the hood but when I drive my 1996 Impreza I never feel the abs kick in and I can lock up the brakes. Am I missing something or is something busted somewhere? There are no abs or check engine lights on in the dash, is there a fuse or relay somewhere that I can check?
Edited by provin1327, 08 January 2014 - 01:43 AM.
#2 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,038 posts
  • Grand Valley, PA
Posted 08 January 2014 - 02:12 AM
You should be okay. If you can try it on a slippery surface is when you'll feel it kick in. Slushy, snowy, muddy roads and it should show up. If not, then yeah something might be off.
I'm not a fan of ABS for myself though. It's disabled on the cars I have that came equipped with it. Pumping the pedal does the same thing but with a human brain operating it instead of a computer.
#3 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 08 January 2014 - 08:54 AM
I tried it on some snow, locked up pretty quick, going to check the fuse box first
#4 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 08 January 2014 - 03:10 PM
All the fuses look ok, anyy ideas on what to test first?
#5 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,912 posts
  • Near Cortland NY
Posted 08 January 2014 - 08:28 PM
Make sure the ABS light comes on key on, engine not started.
Check for power to the unit, key on.
#6 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 09 January 2014 - 05:10 PM
DO you have an ABS light on on the dash? Are all the fuses in place under the hood?
#7 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 09 January 2014 - 05:21 PM
There is no abs light that lights up on the dash with key on
#8 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 09 January 2014 - 08:47 PM
On the ABS pump itself there is a cover where some relays sit. I wonder if one of them have been removed.
#9 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 09 January 2014 - 09:15 PM
There is one relay and one big plastic coverish thing that I cant seem to pull out
#10 Gloyale
Gloyale
    It's a sickness
  • 10,835 posts
  • Corvallis, OR PNW
Posted 09 January 2014 - 11:30 PM
Are the fuses in the holder for the ABS???
#11 provin1327
provin1327
    Advanced Member
  • PipPipPip
  • 42 posts
  • Colorado
Posted 10 January 2014 - 10:04 AM
Yes all the fuses look good
