What spare tire size for my 96 legacy wagon?
4 replies to this topic
#1 Grasshopper2.2
Grasshopper2.2
    Advanced Member
  • PipPipPip
  • 32 posts
  • White Salmon, WA
Posted 09 January 2014 - 10:45 PM
So I put some 205/55/16 wrx wheels on my 96 legacy l wagon, and need to find a spare tire that is the same diameter and will fit in the spare tire compartment in the hatch.  I used to be able to carry a full sized spare with the 14's, but I tried one of the 205/55/16's and the diameter fit perfect, but the width was to thick and the lid won't close.  The factory spare/donut is over an inch smaller diameter than the 205/55/16.  I figure that's not good on the AWD  if I have to go very far on it...  I thought, just get a factory spare from a 2002-04 wrx, but they appear to be the same size as the one I have (T135/70/D16)?
#2 soobie_newbie67
soobie_newbie67
    Eat, Live, Breath Subaru
  • 471 posts
  • Kennewick
Posted 10 January 2014 - 02:27 AM
You need a spare from an Outback.
#3 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 10 January 2014 - 08:14 AM
You could still use the donut if need be. Just put the donut on the rear axle, and insert a fuse into the FWD fuse holder under the hood. Inserting the fuse, changes the car to front wheel drive only.
Once tire is repaired, and all 4 tires are the same size again, then pull the fuse to have all wheel drive operational again.
#4 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,971 posts
  • Charlottesburg, VA
Posted 10 January 2014 - 04:34 PM
If you rip the foam blocks off the bottom of the cover over the spare does it sit down low enough? I put an outback size spare in my 96 and it fits pretty close. Had to re-arrange one of the tabs at the back that holds the spare cover up.
A 195-70-14 should be pretty close and still fit in the spare tire well.
Tire size calculator here: http://www.tacomawor...55r16-195-70r14
#5 Grasshopper2.2
Grasshopper2.2
    Advanced Member
  • PipPipPip
  • 32 posts
  • White Salmon, WA
Posted 12 January 2014 - 10:04 AM
Thank you, for all of the replies!  Great thoughts.  I'm gonna check to see if I can take out some foam or anything to make it fit, and if not I'll find an outback spare or a 195-70-14!  Sorry for the slow response, got busy....
