01 vdc heater blower relay
heater blower vdc 2001 relay resister
4 replies to this topic
#1 monk50
monk50
    USMB Regular
  • PipPipPip
  • 88 posts
  • Albemarle, NC
Posted 14 January 2014 - 07:48 AM
A friend has a 2001 Outback vdc.
The heater blower stopped blowing.
It will not blow on any speed.
I found  fuses behind the change door to the left of the steering wheel, in addition to the fuse box under the hood.
All fuses were good.
Can anyone tell me where exactly is the blower relay on the 2001 Outback VDC?
Thanks
monk in NC
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 14 January 2014 - 11:23 AM
I think it is located in the far left side of the dash area but not positive of that. You might try running power directly to the motor to verify it is okay if you haven't done that already.
#3 monk50
monk50
    USMB Regular
  • PipPipPip
  • 88 posts
  • Albemarle, NC
Posted 14 January 2014 - 06:30 PM
Thanks.
If anyone know specifically where the relay is located I would appreciate the help.
Thanks
#4 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 14 January 2014 - 09:45 PM
In case you aren't aware of it, the resistor pack is on the return side of the circuit. Check to see if power is getting to the motor while the selector switch is set to full speed. If you do see power you should be able to ground the return side of the motor and make it run and verify the motor is okay. It would also mean the relay is okay.
#5 monk50
monk50
    USMB Regular
  • PipPipPip
  • 88 posts
  • Albemarle, NC
Posted 15 January 2014 - 04:33 PM
Thanks,  will check.  All good suggestions and greatly appreciated.
Monk
Still hunting for the relay location.  Thanks
Edited by monk50, 15 January 2014 - 04:55 PM.
Also tagged with one or more of these keywords: heater, blower, vdc, 2001, relay, resister
