jono Posted January 19, 2014 Share Posted January 19, 2014 Four different part numbers for the EA82 flywheels. I seem to recall a suggestion to use a 2WD flywheel in 4WD vehicles for a lighter flywheel/zippier drive. At least may have been EA81 info ??? Anyone compared 2 & 4WD flys? Done this performance enhancement ? Found issues ? I am guessing if the 4WD are heavier, there is less meat to them, further distance from the box -AND a need for a longer clutch fork pivot. I have clutch issues, based around using a 2WD flywheel and its clutch from an EA82T behind EA82 on a 5MT DR 4WD. Yet to measure installed flywheel or clutch pivot, but have found the pivots can be about 35mm and 40mm long If I have the shorter one installed, may save me, may need to fit a 4WD flywheel. If I have the 40mm - I is in trouble if the 4WD fly no fix. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 19, 2014 Share Posted January 19, 2014 Non-turbo 2wd flywheels have a 1" diameter smaller contact face Quote Link to comment Share on other sites More sharing options...
