1996 subaru legacy wagon wont start
wont start not running need help
5 replies to this topic
#1 hippy62378
hippy62378
    Newbie
  • Pip
  • 2 posts
  • canon city, colorado
Posted 30 January 2014 - 08:22 PM
I have a 1996 legacy ls wagon 2.2 auto. the other day it went into a limp mode. and when we shut it off it wouldn't start. we had the codes ran and no codes the coil pack was rotted and grounding out on its mounting bolts. we replaced the coil pack, and it still didn't start. I have checked that it is getting spark at the plug and it was great. then I went through the fuel pump, relay and filter. the fuel system works past the fuel filter the injectors are getting power. I am so lost. please help
Edited by hippy62378, 30 January 2014 - 08:27 PM.
#2 snofool
snofool
    New User
  • PipPipPip
  • 100 posts
  • Wyoming
Posted 30 January 2014 - 10:28 PM
check all connections, airflow, vacuums,If mass air sensor is out or unplugged it won't start. Clean battery terminals and attachment points. Does it crank over?
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 30 January 2014 - 11:17 PM
Try holding the gas pedal on the floor for a few seconds while cranking then release it. If it starts its getting too much fuel and flooding.
Could also have jumped timing.
#4 hippy62378
hippy62378
    Newbie
  • Pip
  • 2 posts
Posted 31 January 2014 - 12:03 AM
the timing is right on I have checked that and it was also replaced a month ago when I did the water pump it cranks just fine no dragging or anything and there is spark and fuel after the filter it ran fine all the way up to Colorado springs from canon city and that's a bout 40 miles then we parked the car came out hours later and it started just fine then when we got about a block it started doin this stuff and we changed the coil pack and that was it  crank but no start I went through all of the fuel system except the injectors but I did check that they are getting power
#5 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,955 posts
  • Texas
Posted 31 January 2014 - 11:54 AM
maybe crank or cam position sensor?
#6 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
Posted 31 January 2014 - 12:48 PM
I would check the timing anyway. The tensioner could have gone bad and let the belt go slack.
Also tagged with one or more of these keywords: wont start, not running, need help
