electrical problem....
20 replies to this topic
#1 efseiler
efseiler
    USMB is life!
  • 386 posts
  • Passumpsic, Vermont
Posted 31 January 2014 - 12:19 PM
Hi,
   I noticed that when braking the lights dim due to a voltage dip.  I'm a little concerned about that and I'm thinking it could be the battery, a voltage regulator, alternator or a bad ground somewhere....
What do you guys think?
Also, the lead that connectes the switch for the intermittent wiper pump (the one the goes in the hole dead center on the firewall) is severed...maybe that too may be part of the issue.
Thanks guys!
--Damien
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 31 January 2014 - 12:45 PM
Alternator may be getting tired. Thing is, my car has done exactly the same for the past 4 years. Now that I say that the alternator will probably kick the bucket next week, but here's no real reason to rush out and buy a new alternator unless the problem gets worse, or the charge light in the dash comes on.
#3 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 31 January 2014 - 02:49 PM
I hear ya.
Is it normal for CEL lights to switch themselves off?  I've been getting an EVAP code periodically but after a day or two the CEL automatically switches off...
Thanks,
--Damien
#4 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
  • North Central Wisconsin
Posted 01 February 2014 - 08:36 AM
have the same dimming issue with my new to me 95 Legacy - not real bad yet, and weather has been very uncooperative. Was mentioned to me to check all grounds as well...
I do know that the battery in this car is getting kind of old - I should probably replace it sooner rather than later...
#5 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 01 February 2014 - 09:32 AM
Yeah the battery in mine is old and a tired as well and I'm too lazy to blow 90 bucks for a good one.
It could just be how these cars are wired, too...they may develop similar symptoms across the board like that.  :-/
#6 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 01 February 2014 - 09:44 AM
I am too broke to blow the $90 for a new one right now! LOL
still playing catch up after finally getting a job in September after being unemployed for 4 years :wacko:
Getting the 95 up and running ate up nearly all the reserve I had left. Wasting $500 on a junk tranny didnt help any... and no, I didnt get any money back on that one - the crooks! :angry:
#7 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 01 February 2014 - 10:17 AM
I hear ya.
Thanks,
--Damien
Yes, my OBW has been doing that with the evap code. Pretty sure it is my gas fill pipe causing the problem. Recently removed it, sealed the rust holes best I could, only to have the CEL come on two weeks later, but the CEL turned itself off a few days back. However, I wouldn't be surprised if it reappeared.
#8 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 01 February 2014 - 10:50 AM
I had a 99' Outback that I bought from a real sleeze who owns a subaru repair shop in Lakewood, CO and when he sold it to me I noticed the headlights would dim when I pressed on the brakes, I checked the battery and he had installed some off the wall tiny battery from who knows what, maybe a atv? Haha. It was amazing it worked, I went to advance and bought the correct battery for the car and it fixed that problem. Just my 2 cents.
#9 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 01 February 2014 - 12:58 PM
A weak battery can cause the lights to dim more than they would normally with a good battery installed. It is a good idea to clean the battery connections and the main chassis ground connections to help stop voltage drops in the electrical system. Make sure the fan belt is tight and isn't slipping on the alternator. Costco has some decent batteries for around 70 dollars. You may what to get the charging system checked out when you do get a new battery to check the condition of the alternator output. Also have the AC ripple voltage checked to make sure the diodes are okay.
#10 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 01 February 2014 - 06:10 PM
well if the belt were slipping I reckon it would wear out pretty quickly....
I find the the EVAP code can be eliminated by really screwing the cap on tight...another thing that can cause it is excessive water/alcohol in the gas mix.
It seemed strange to me that the light would automatically switch off...I guess that's a built-in feature for the minor codes.  Something major I guess would stay illuminated.
Yeah probably the battery then...it's an old, cheap Walmart one...probably a decade old for all I know...
Cheers!
--Damien
#11 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 01 February 2014 - 06:17 PM
Glad you got a job back...sitting around at home twiddling your thumbs and putting up with the missus can be a real drag, I know.
Dealing with Le Car is a real art...the guys at the shop make it look easy...but give they customers stuff that's...well...real hard.
#12 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 01 February 2014 - 09:34 PM
umm - I am the "missus" LOL (its ok - common mistake online ;) )
since I have to go to town tomorrow anyway, gonna run by Advance Auto and have them do a charging system check - see just how bad things really are. Yesterday was payday, so I might be able to swing a new battery if I need it bad enough.
#13 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 02 February 2014 - 09:10 AM
You may be...but you may not be the only one.  :-)
--Dame Ian
#14 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 02 February 2014 - 07:37 PM
hehehe
well, got the charging system check done - just as I suspected - battery is old and weak. Supposed to be 640 CCA - only registering 495...I see a new battery in my near future.... :huh:
#15 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 04 February 2014 - 09:19 PM
turns out the local farm & home store had batteries on sale this week - got myself a 72/24 month for $70 AND free installation and a $5 credit for the old battery!  And the best part - the headlights no longer dim when hitting the brakes!
#16 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
Posted 05 February 2014 - 12:07 PM
Last time I was at tractor supply they had Exide (IIRC) batteries with 72 month warranty for about $79. That's about $50-60 less than a crappy parts store battery around here.
#17 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 05 February 2014 - 01:06 PM
That was a good price on a battery @ $70. Glad your dim light problem is corrected.
#18 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 05 February 2014 - 06:38 PM
actually - early this morning I discovered the dimming isnt completely gone - but it is much less noticeable - as in barely there - really have to be watching for it to notice it. When the weather warms up enough that I can tolerate being out for more than a couple of minutes at a time, I will begin checking grounds...
#19 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 05 February 2014 - 08:15 PM
A slight dimming of the headlights is normal. The alternator output drops down slightly at idle speeds so voltage at the battery also drops down some. What you are seeing is most likely from that but it is good to go over connections and clean them just to be sure they are okay.
#20 efseiler
efseiler
    USMB is life!
  • 386 posts
Posted 06 February 2014 - 08:50 PM
I just got my exhaust completely fixed today (there were numerous cracks and seepages in the nearly 15 year-old components) and it definitely alleviated that symptom tho it did not eliminate it.
#21 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
Posted 07 February 2014 - 07:15 PM
yeah - this car is relatively new to me and by the time it was road worthy (after Thanksgiving) it was already quite chilly out and temps went downhill from there - we have had 40 something days straight of below zero so I havent really been too motivated to really go over things yet. one of these days it will warm up (i hope...) :unsure:
