Repair trouble shooting help.
3 replies to this topic
#1 Vmech
Vmech
    Newbie
  • Pip
  • 6 posts
  • Cleveland, OH
Posted 06 February 2014 - 02:37 PM
Where is the appropriate place to post mechanical problems  I am having on this forum?
I have several problems
2001 Legacy hatchback automatic transmission.
Thumping of driveshaft/transmission(?) in first gear (I think). Like a drum roll with 5-8 thumps then fine. It feels like it is coming from the middle of the vehicle just behind the front seats.  Also I can hear a very faint high pitched metal on metal scraping when crawling forward.
Smell of fuel in cabin compartment when in idle.
Scariest of all a the car struggling on acceleration and  pushing back (like being in to low a gear) then slightly accelerates a couple times. The tachometer bounces up and down a little reflecting struggling of engine/transmission(?). The check engine light flashes during this Shifting in to neutral then back in to drive while still moving corrects this.
When ever I shift into drive even when stopped the car starts to idle roughly
I have not had the error codes read before the this last problem occurred
and they where and Evap system leak small and a Transmission Knock Sensor (I think I)
I am just trying to get a better idea of what  the problems are
Oil is good (although I have a small oil leak which I will try and address if the other problems are not fatal)
Transaxle fluid level is good. I changed it about a year ago
Going to do the usual things
Change
spark plugs/ cables
fuel filters
PCV valve
and investigate the EGR
Any help would be appreciated
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,736 posts
  • East Coast
Posted 06 February 2014 - 02:55 PM
give us the codes - the actual numbers.
if it's the knock sensor, those are easily replaced in a matter of minutes, cost $15 on ebay, and fail due to age so no big surprise there.
they also can cause severe performance issues.
#3 idosubaru
idosubaru
  • 23,736 posts
  • East Coast
Posted 06 February 2014 - 02:56 PM
and you should post threads about this car in the "Newer GEneration" area of this forum here:
http://www.ultimates...-wrxwrxsti-svx/
#4 Vmech
Vmech
    Newbie
  • Pip
  • 6 posts
  • Cleveland, OH
Posted 06 February 2014 - 03:22 PM
P0442 and P0327
