Impreza 1996 clutch replacement by pulling engine out
ej20 clutch nonturbo
26 replies to this topic
#1 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 08 February 2014 - 10:48 AM
Hi again!
It turned out that I didnt have such a luck I hoped for in my previous thread Impreza 1996 clutch issue. After replacing engine coolant temp sensor and cleaning crankshaft and camshaft position sensors which were covered in oily crap the car acted more spirited but in two weeks it was pain in the butt to keep up even in city speeds. Since estimates for clutch repair job were 70-90% of car purchase price I decided to try it myself.
Realized after mounting gantry crane and attaching chain hoist and after that engine leveler that the max raise capacity wouldnt be enough if front of the car is resting on jacks. How much do I need clearance to lift ej20 engine from bay?
#2 86BRATMAN
86BRATMAN
    Elite Master of the Subaru
  • 3,933 posts
  • Tazewell Virginia
Posted 08 February 2014 - 10:50 AM
Remove the hood for extra clearance, and pull the radiator. I've done a clutch on an XT without ever pulling the engine completely from the car lol.
#3 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 08 February 2014 - 01:25 PM
Hood is already pointing almost straight up and I'm definitely removing radiator. But since this is my first time doing this level repair I'd like to completely remove engine and check rear crankshaft seal and valve cover gasket for leaks in comfortable(!) position.
Chain hoist and leveler shorten lifting max with about 22" (55cm) so I might remove leveler and use short chains instead. Damn this is exciting! =)
#4 lmdew
lmdew
    _______
  • 3,730 posts
  • Colorado Springs
Posted 08 February 2014 - 09:20 PM
The engine does not weigh that much.  You could build a simple A frame out of 2x4 with a 2.x6 cross beam.  That ill hold the engine and give you plenty of reach to lift it clear of the engine bay.
Read up on the rear breather plate and leave the rear seal alone unless you know for sure it's leaking.  99.9% of the time it's the breather plate leaking.
Larry
#5 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 10 February 2014 - 01:52 PM
Excellent, now I'm in the point to separate engine from transmission, unfortunately driver side of block doesnt seem no realize it. Right hand side separates almost inch but left hand resist. I followed partly Subaru Impreza 93-96 repair manual and it differs where it says  to remove plug to screw in bolt into release fork shaft to remove it. Theres no plug nor threaded hole and I figured that applies only to turbo models. At home I checked http://www.uklegacy....-by-step-guide/ and this guide doesn't mention about plug thingy either so I guess I just need a bigger hammer =)
#6 lmdew
lmdew
    _______
  • 3,730 posts
  • Colorado Springs
Posted 10 February 2014 - 06:45 PM
Make sure you are clear of the Frame with the engine mount.
The alignment pins can be rusted in.  You can try driving them forward or put a large screwdriver between the engine and trans and then move the passenger side back towards the trans.
Keep the space between the engine and trans as close to the same as you can side to side.
#7 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,938 posts
  • Charlottesburg, VA
Posted 11 February 2014 - 12:36 PM
The alignment dowel is seized in the bell housing. DO NOT try to pull the free side away or you will crack the bellhousing.
Put a prybar or large screwdriver in the bellhousing on the stuck side about halfway down and try to pry it apart.
If you don't have room to get the engine over the front support, just take the car down off the jack stands. The trans will rest on the cross member, so you dont have to worry about holding it up.
#8 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 11 February 2014 - 02:12 PM
Whee, its out! Sprayed a bit WD-40 into crack, more wiggling, chisel + hammer combo, shaking and prying with crowbar it gave in! After removing flywheel no oil leaks from rear oil seal nor plastic baffle plate, but driver side valve cover gasket and plate held by two bolts on opposite side probably end of camshaft leak nastily.
Wonder I get by just by replacing clutch disc and release bearing and scuff flywheel and clutch cover side with sandpaper or angle grinder since they are quite smooth.
#9 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,043 posts
  • Honolulu HI
Posted 11 February 2014 - 02:28 PM
Congratulations Tremmor!  Good going!  Since you're already in there might be advisable to replace the plastic baffle plate with a metal one anyway.
Good luck!
#10 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,938 posts
Posted 11 February 2014 - 06:27 PM
Replace the whole clutch. The spring in the pressure plate weakens with time and you lose pressure on the clutch disc.
Replace the plastic separator plate while its out. They crack and warp and start leaking.
Also replace the O-ring under the diamond shaped cover opposite of the rear main.
If the rear main is dry leave it alone.
#11 ocei77
ocei77
    Eat, Live, Breath Subaru
  • 853 posts
  • Monticello,NY
Posted 12 February 2014 - 10:55 PM
To add.
Replace the springs (dealer only part) for the throw out bearing and closely examine the fork for any cracks, if so replace it.
O.
#12 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 14 February 2014 - 02:36 PM
Sachs clutch kit arrived but unfortunately lack of other stuff delays installation some days. Oh, and those two lower nuts in transmission case that are hard to reach I found that using dual box wrench, mebbe it was 14mm and 13mm, and slide hammer with hook attachment, it was easy to break open without busting knuckles.
#13 subnz
subnz
    USMB is life!
  • 229 posts
  • Glenorchy New Zealand
Posted 16 February 2014 - 02:21 AM
Totally agree engine removal for clutch replacement,
This is how I do it as well particularly if don't have access to a hoist / pit.
Also agree to purchase a full kit,  it should include clutch disc, pressure plate, release bearing and spigot shaft bearing (housed in centre of flywheel.) other wise false economy / job not done properly.
A lot easier than groveling on the ground with axle stands removing transmission.
And agree, a good opportunity to deal to oil leaks while out ie  flywheel/crank oil seal, cam cover gaskets, easy spark plug replacement etc and
 A  good opportunity to do cam belt / water pump etc replacement if due as well.
While clutch apart take flywheel off and take to an automotive recondtioners machine shop and get the face of flywheel machined if its scored from worn previous clutch .
Otherwise new clutch will shudder on engagement if you don't do this.
Edited by subnz, 16 February 2014 - 03:19 AM.
#14 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 16 February 2014 - 03:18 AM
Closer visual inspection after cleaning flywheel revealed hairlinecracks, the longest is about  0,6" (15mm) long.
General overview after scuffing with 120 grit paper
http://oi60.tinypic.com/2u77ot4.jpg
Closeup crack in flywheel, you can feel it with fingernail
http://oi58.tinypic.com/2r5f7lt.jpg
I'm starting to think there is no such a thing as quick clutch job unless you happen to have all spare parts already. =)
#15 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 February 2014 - 08:48 AM
the cracks are fine, you can rough up the surface with sandpaper to take out the shine.
#16 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,938 posts
Posted 16 February 2014 - 03:13 PM
If you have time to wait, get it machined to try and take most of those out. Probably wouldn't cause a problem with engagement but they can cause premature wear on the clutch disc facing that runs against the flywheel.
Edited by Fairtax4me, 16 February 2014 - 03:16 PM.
#17 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 23 February 2014 - 01:10 PM
Damn, improvised clutch disc alignment tools made by rolling masking tape around torx socket, or masking tape around tire valve installation cone didnt do the trick. 3 hours wasted wiggling engine back and forth until figured to insert 12mm drill bit into pilot bearing and then place old pilot bearing after pressure plate. Now it was easy to eyeball center of clutch disc and fasten bolts, after that engine went in smoothly. :)
#18 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,938 posts
Posted 24 February 2014 - 12:20 AM
Last time I made a pilot tool it was with a large 1/2" drive socket that fit into the clutch hub, slipped over a 3/8" socket extension wrapped with electric tape so the big socket fit snug.
On the end of the extension I used a socket that fit into the pilot bearing. I think it was 10mm. Worked out better than the crappy plastic alignment tools they supply in clutch kits.
#19 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 25 February 2014 - 02:33 PM
Whee, drove it out from garage carefully and tried to get feel for low grabbing clutch. Then headed to gas station and soonish started to listen whats that sound, its was like dry and loud bearing. Fortunately it was only hood support that was loose and it was rubbing against powersteering pulley.  Gonna adjust clutch cable later to get it grab a bit higher like it was before operation.
I didnt replace baffle plate since dealer couln't give date when it would arrive. But if I learnt something from this clutch  change episode it would be: Be prepared. Order stuff beforehand, get used flywheel and have it machined, Take pictures what goes where, take pictures from other angles too. Make notes. Put parts in safe place where you find them, label hoses. Get torq specs etc.
Thank you very much for helping me out! Saved a big penny and learned lotsa of new stuff! =)
#20 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,043 posts
  • Honolulu HI
Posted 25 February 2014 - 02:37 PM
Congratulations, Tremmor.  Hope you get her adjusted okay.  Enjoy your Subie again!
#21 forester2002s
forester2002s
    Subaru Fanatic!
  • 836 posts
  • Vancouver Canada
Posted 25 February 2014 - 04:46 PM
And thanks for posting your progress, including the glitches.
I'm going to be doing the same work on my Forester soon, and reading this has helped me get prepared.
#22 subnz
subnz
    USMB is life!
  • 229 posts
Posted 03 March 2014 - 05:27 PM
                    Posted 26 February 2014 - 08:33 AM
Yep its all a leaning curve  DIY,  I remember from  doing my 1st clutch not refacing flywheel surface had clutch judder /chatter issues but they get less / sort of go away after a while when clutch disc wears / beds in.
Sorry forgot to mention  / talk about making / improving a clutch disc alignment tool (out of a series of sockets on rod) etc
back in previous message but you got that figured out.
#23 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 06 March 2014 - 01:36 PM
Update: Don't forget to attach alternator plug all the way in so it locks or you might have to get your car towed when battery dies. Now I know it doesnt throw charging warning light at dash! :P
#24 Tremmor
Tremmor
    New User
  • PipPipPip
  • 50 posts
  • Finland
Posted 17 March 2014 - 10:50 AM
Update: on the way to home I noticed nasty sound coming from front of the car it was like something was loose. Gear in neutral pressed gas pedal and noise got louder, but it was still there when car was idling. Then I noticed that pressing clutch pedal made noise quieter, turned clutch cable adjustment screws few turns tighter and sound went away. Either those screws need some thread locker or some glue type thingy to prevent vibration to loosen them or clutchdisc got broken in maybe, I dont know.  Anyway, time for short test drive to verify theory.
#25 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,938 posts
Posted 17 March 2014 - 10:27 PM
Did you replace the clips that hold the release bearing to the release lever?
When those break the release bearing rattles around between the lever and the pressure plate.
