BoostedBoxer421 Posted February 10, 2014 Share Posted February 10, 2014 Hi, I have an '87 GL Turbo, and if I floor it or pump the accelerator between 2.5k and 4.5k it starts to miss and sputter, but if I gaive it say 3/4 throttle, it will rev up perfect My first thought was the intake was leaking because it started in boost range (boost light comes on at 2k every time) but can't find any leaks.. Timing advance? Bad pcv letting air in before turbo? Maf sensor? Idk what to check now.. -Thanks fer any help! Just got two feet of snow at my house and my wagon still goes anywhere! Quote Link to comment Share on other sites More sharing options...
naru Posted February 11, 2014 Share Posted February 11, 2014 Weak fuel pump/clogged filters. Measure the fuel pressure on the fly if you want confirmation. It should maintain 43 psi at full boost. I would bet money it does not. Don`t pump it.It is not carbed. Quote Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted February 11, 2014 Author Share Posted February 11, 2014 Fuel pump is stock and pretty weak. I have new pump I bought for my '87 RX to use though And not pumping pedal to keep it running, just noticed it while driving on ice and through snow lately Quote Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted February 11, 2014 Share Posted February 11, 2014 I'd double check the timing and hook up an analog boost gauge to make sure the pressure is not spiking. These are equipped with an overboost switch which cuts the fuel (which is a bad idea, IMO. Should be an ignition cut) when the boost pressure is too high. Otherwise, check the normal rubber parts for cracks and check the TPS for smooth operation and consistent resistance readings. Quote Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted February 11, 2014 Author Share Posted February 11, 2014 going to get boost gauge, but as soon as i pulled TPS off it kinda crumbled in few pieces, so other than weak pump i may have found my problem with that. and recently change both timing belts.. when i check the timing with a light the line kinda wavers about 2* back and forth going from about 17*-19* :/ this engine has 235,000 miles all stock and runs great. i plan on going over as much as i can to restore it Quote Link to comment Share on other sites More sharing options...
