nmos Posted February 14, 2014 Share Posted February 14, 2014 The U-Joint is going out on my '97 Impreza and after seeing the $700+ prices for new replacements I'm considering going to the local Pick-A-Part but I could use some advice on what other models/years would be compatible. The original OEM part # was 27031fa020 but it seems to have been superseded by 27031fa140 . I figure that at least any 96-97 Impreza or Forester with a manual transmission should be fine but are there any other models/years that would work? Anything, in particular I should be checking for on the replacement besides mileage and giving the U-Joint a shake? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted February 14, 2014 Share Posted February 14, 2014 93-01 impreza, 02-07 impreza. Forester has a different center bearing so the drives shift will be at a different angle if you use one of those. You can usually get a decent low mileage one off ebay for 100 or less shipped. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 14, 2014 Share Posted February 14, 2014 (edited) if it's a two piece shaft - the rear sections are often the same auto or manual. it's the front half that's different lengths. that's true of older geneartion stuff and it hink newer gen too...maybe someone can confirm. if you just need the rear half then you may have more options. www.car-part.com there's also a replacement for the staked in ujoint if you dont' mind cutting out the old one and working this one in place or having a shop do it: http://www.ebay.com/itm/SUBARU-FORESTER-LEGACY-OUTBACK-BAJA-SVX-LOYALE-U-JOINT-DRIVE-SHAFT-U-JOINT-3-/271305510733?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1997|Make%3ASubaru&hash=item3f2b118f4d&vxp=mtr there are cheaper ones out there - someone posted a link to like a $25 variant last year. legacy/outback transmissions and rear diffs are interchangeable with impreza's - wonder how/why driveshafts differ - probably chassis length and mounting i guess? in which case are the front halves or rear halves different or both? Edited February 14, 2014 by grossgary Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 14, 2014 Share Posted February 14, 2014 Legacy driveshaft as a whole is longer, by whatever the difference in wheelbase is. I can't say for certain if either half of it is the same, maybe someone else can chime in. Quote Link to comment Share on other sites More sharing options...
nmos Posted February 14, 2014 Author Share Posted February 14, 2014 93-01 impreza, 02-07 impreza. Forester has a different center bearing so the drives shift will be at a different angle if you use one of those. You can usually get a decent low mileage one off ebay for 100 or less shipped. Any problem re-using my existing center bearing? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted February 15, 2014 Share Posted February 15, 2014 Any problem re-using my existing center bearing? Nope. Not if you can remove it. Quote Link to comment Share on other sites More sharing options...
nmos Posted February 16, 2014 Author Share Posted February 16, 2014 I got the old drive shaft out today and the front U-Joint was in pretty bad shape (probably would have come apart if I'd driven it much more) but the others look fine. Also noticed the seal at the front of the rear diff is leaking. I guess this was as good a time as any to find that. Wish me luck at the yard tomorrow, it looks like they have 2 95 Impreza's and at least 2 98 or newer Foresters. Quote Link to comment Share on other sites More sharing options...
