If they came on the car, don't have uneven pad deposits, aren't cracked from the drilled holes or at the minmum thickness - just run them.
But, as said above, a daily driver does not get any benefit from them. In fact, modern pad materials even for racing do not outgas as badly as in the past so, even some track cars wouldn't need them. Of course, if you're gonna track the car regularly, you would need to use w'ever combo rotor and pad works best for you.
If you plan to refresh all 4 corners, get Centric premium rotors and try Centric PosiQuiet Ceramic pads - good value. If you track occasionally - or zoom around in a spirited manner all the time, upgrade the pads to Stoptech Street Performance.
On a car that old, you should consider all new rubber lines too. maybe 4 in the back (?) and 2 up front? not sure. That old rubber probably balloons a lot and fresh lines won't - more solid brake pedal feel. Fluid flush might be a good idea too.
Edited by 1 Lucky Texan
got it. You might consider slotted only but, as fast as you will go thru brake components, you'd likely change rotors before any cracks showed up around drilled holes anyway.
someone at NASIOC might have experience with the ebay parts.
I'm not running a car like you are but I've had good advice from the guys at http://www.knsbrakes.com/c/home
