replaced pads, now a knocking in front.
5 replies to this topic
#1 djellum
djellum
    Eat, Live, Breath Subaru
  • 774 posts
  • Vancouver WA
Posted 22 February 2014 - 11:16 PM
Hey,
replaced my brake pads in the front today, and now there is a pronounced knocking noise from the front right when under light braking.  everything works fine, stops well both lightly and hard, just makes a knock noise that is timed with the rotation of  the tire.  it won't do it under hard braking, but light to medium makes a lot of noise and it wasn't there before.
Ive checked all the bolts, lug nuts, etc.  I only removed the one bolt to allow the caliper to open and didn't touch anything else.  used the tool to spin down the caliper, used caliper lube, hand brake is adjusted, I cant think of anything that would cause it all of a sudden.
anyways, just throwing this out there, ill take another look tomorrow and see if I just missed something obvious.
#2 ruparts
ruparts
    Subaru Nut
  • 565 posts
  • hooper, co
Posted 23 February 2014 - 02:00 AM
hi,
  you probably already know about it but,  on the final turn screwing the pistons back into the caliper you have to leave the piston in just the proper position to accomodate that little nub on the backside of the brake pad, otherwise the pad will not sit flat against the piston and can wobble somewhat.    check all the pad retainers clips and spring, to be sure they have not jumpped out of position.
#3 Gloyale
Gloyale
    It's a sickness
  • 10,546 posts
  • Corvallis, OR PNW
Posted 23 February 2014 - 12:40 PM
So you put new pads on un-turned old scored up rotors?
That's your noise.
#4 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 23 February 2014 - 07:55 PM
I think a better approach would have been to ask IF his rotors are true and smooth, rather just assume they're shot.
#5 vwbus
vwbus
    Newbie
  • Pip
  • 2 posts
  • alaska
Posted 23 February 2014 - 09:38 PM
you may have the "wrong "rim on the front of the car some older rims will have the caliper knocking with new pads in them . You will see a littler rub line on the inside of rim . Good luck
#6 djellum
djellum
  • 774 posts
  • Vancouver WA
Posted 24 February 2014 - 12:40 AM
best guess is that its a warped rotor (they are not worn terrible, but that one makes a small scrap sound when moved by hand.  doesn't shimmy or anything when braking.  Ive had plenty of crap cars that had noticeably warped rotors but they never made noise before.  it has the same rims, same rotors, calipers, etc.  the only thing different between the day before and after was the pads
ill pick up a new rotor for it and see if that takes care of it
