Urgent ea81 SPFI conv ignition condenser question
7 replies to this topic
#1 tweety
tweety
    USMB Regular
  • 345 posts
  • Euroa Victoria Australia
Posted 03 March 2014 - 09:12 PM
My question is-  there is a transister mounted on the coil mounting bracket.  There is also a condenser nearby. There is a black and white wire from +ve side of the coil to a two pin plug see pic and the second wire a black one goes to ground.
As you can see from the picture there is nothing plugged into this plug. I assume it is a plug in condenser. Can someone enlighten me about it, what effect it will have on the ECU if missing?  I beleive it has more importance for the operation of the ECU than noise suppression in a radio. Also what specifications has it?  As I'll try to hunt a similar condenser in Oz.
Finally I do have a spare coil mount with transister and a different style of condenser plug on it. A black cylindrical type. think it might be from a later model. but I dont have the other plug part that goes to ground.
Hope I can get some answers and pics to please.
#2 ruparts
ruparts
    Subaru Nut
  • 565 posts
  • hooper, co
Posted 03 March 2014 - 11:41 PM
hi,
 i know the piece on the coil bracket is necessary, and the bracket must be grounded , but  i  can't say about the other wires and condenser.
#3 jono
jono
    Reader and writer
  • 1,684 posts
  • Southern Hemisphere - AUS
Posted 04 March 2014 - 06:22 AM
so...these spfi EA82's used similar ignition set up like 87.5 XT and mpfi including turbos, and an optical dizzy ?
#4 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 04 March 2014 - 10:52 AM
Just for radio noise the most important thig is that the coil braket is grounded 100% They also had plugs going to nowere for Subaru test diagnostic tool to hook up and check ig circuit that's what I think you are looking at
#5 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 04 March 2014 - 12:35 PM
There shouldn't be a condensor on the SPFI coil setup.
#6 tweety
tweety
    USMB Regular
  • 345 posts
Posted 05 March 2014 - 05:27 AM
A capacitor  .47 microfarad rated at 250 volts  I've been told is suppose to be there to stop voltage spikes?  Maybe my conversion wasnt complete etc.
#7 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 05 March 2014 - 11:45 AM
Could be, but It isn't shown on the Wiring diagrahms in the FSM though.
#8 tweety
tweety
    USMB Regular
  • 345 posts
Posted 28 March 2014 - 08:13 AM
thanks Gloyale.  have taken off the sPFI system and going to put on a 38/38 weber with the SPFI manifold. back to basics.
