weber help
9 replies to this topic
#1 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 02 May 2004 - 11:16 PM
I installed a weber on my 83 wagon today. After intalling it i tried to start it up. After a quick crank i started up and idled for about 4 sec. then it died. I tried to start it again and i wont fire up. I let it sit and tried it again. Once in a while it will pop once but thats as close as it comes to firing. Before installing the weber i put in a new fuel filter, coil, spark plugs, wires, dist. cap and rotor, so i have pretty much eliminated those from the posible culpretes. If any one has any ideas why i wont start would help a lot.
Thanks
David
#2 CamoMan
CamoMan
    USMB Regular
  • PipPipPip
  • 97 posts
  • Rougemont
Posted 02 May 2004 - 11:33 PM
Did you try starting fluid?
#3 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 03 May 2004 - 01:09 AM
I would put the old coil back on and see if it will start. Depending on which coil you installed there have been reports of some bad accell coils surfacing.
#4 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 03 May 2004 - 03:00 AM
Yeah - and make sure your fuel pump is working.... and properly connected.
#5 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 03 May 2004 - 01:47 PM
i doubt it is the coil because the car would start up with the original hitachi carb on, and i can see/smell the gas in the carb after tring to start it up, it seems though that it floods really easy, the barels in the carb have gas pooled up in the bottom after just a few cranks, i'll try the starter fluid though. Also if any one has pics of their weber hooed up, id like to look at them to make sure i every thing installed correctly.
Thanks
David
#6 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 03 May 2004 - 04:00 PM
There's some pics up here from when I first installed mine:
http://www.ultimatev...n.com/cropperr/
Are you sure you have the idle adjustment correct? Try starting it with the pedal fully depressed. Weber's are pretty simple - just keep telling yourself that.
#7 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 03 May 2004 - 08:45 PM
Thanks a lot i had the my fuel filter connected in correctly that was my problem. So the car starts now the the idel is surging, and the linkage seems i not return to its fully closed position. I can't find anything binding but it seems like the spring is just not pulling it closed. It also back fires every time i start it up. Also where do you pick up a lower clearence air filter because i dont have a lift (yet).
Thanks
David
#8 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 03 May 2004 - 09:05 PM
The throttle will not fully close until the choke has pulled off completely. You should also not do ANY adjustments to the carb until the choke is fully heated, and no longer engaged. You will need to rig your own return spring for the throttle as well if you haven't already done so. I just attach mine to the air filter housing, in front of the clip on that side.
The 1-7/8" air filter's are made by EMPI, and you should be able to grab one for about $10 at any VW performance shop.
Backfireing is likely due to improper timing, and incorrect idle mixture. Dieseling is generally caused by this as well. The timing and the idle mixture are insturmental in a properly tuned Weber setup. You'll just have to play around with it.
#9 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 03 May 2004 - 10:21 PM
Thanks for all the help GD, its making me happy to almost have this car road worthy, I bought it in September and have been slowy getting it going. I need to hook up the returnspring, that should fix the that, the surging idel though is confusing though, my only guess is that it is vacume related. ill check for leaks. Other ideas though are still very helpful.
Thanks for all the info it has helped me a lot
David
#10 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 03 May 2004 - 11:01 PM
Sure sounds like a vacuum leak - try spraying around with carb cleaner to see if you can find the leak. The engine will speed up and smooth out when the carb cleaner gets sucked into the leak. The intake manifold gaskets are known for leaking sometimes.....
