Roller rockers and roller cam in big valve hydro ea81?
7 replies to this topic
#1 Captin Hook
Captin Hook
    New User
  • PipPipPip
  • 78 posts
  • Spokane
Posted 13 March 2014 - 04:50 PM
Is it even possible? What is needed other then the obvious? Is it worth it?
#2 BratRod
BratRod
    USMB is life!
  • 580 posts
  • Dallas, Texas
Posted 13 March 2014 - 05:42 PM
Possible? Yes!
Photos, as promised.Beginning, removing AC compressor and all that. Compressor seems to be in good shape, plan on keeping it.SurpriseCrane, SBC roller rockers. Valve cover spacer, so rockers will fit.Custom rocker mount plate, sits behind spacer on top of headAnd here's where it got really interesting:Two welds, one of which is cracked. It appears they cut out the water jacket, welded a large amount of material around the exhasut port, ported it, and then welded the water jacket back on. Lots of work, seems like with a turbo that might not be as helpful as it would be with NA.More detailAnd, definately not stock valve springs. My dad seemed to think that they might be SBC as well. And knowing how Doc Seal seems to have a particular like of SBC parts in projects, I wouldn't doubt it.And more of the head. The intake has been ported as well. I'll try and get better photos of the in head porting next time, as these didn't show that well.Once the water jacket is welded up and everything is put back together, next step is the carb! Everything went very smoothly in the tear down, and most everything shows very minimal wear, leading me to believe this was a NOS engine they put these parts on, and then never really ran it.Also, looking for a drivers side mirror for QS, and a passenger side front turn signal lens if anybody has one laying around. There are a ton more bits it's missing, but going to start with these two!
Edited by BratRod, 13 March 2014 - 05:45 PM.
#3 Captin Hook
Captin Hook
    New User
  • PipPipPip
  • 78 posts
  • Spokane
Posted 14 March 2014 - 10:03 AM
Most of the pictures didn't post.
#4 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 14 March 2014 - 10:13 AM
Sick love it !
#5 Captin Hook
Captin Hook
    New User
  • PipPipPip
  • 78 posts
  • Spokane
Posted 14 March 2014 - 07:01 PM
Alright that covers the rockers, what about lifter, and push rods? What ratio is the rocker, and what's the stud dia?
#6 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 17 March 2014 - 11:15 AM
I see flat springs in there to cool !
#7 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,546 posts
  • Puyallup
Posted 18 March 2014 - 09:39 AM
The cam would have to be ground and treated to accept roller lifters or the lifters will tear it up.  I'm sure Delta can do that. If you can find the correct diameter and height lifters.... Whammo! Bob's your uncle! lol Or find the right diameter and close height then pushrods to make the overall correct height. Rollers are great for freeing HP and reducing heat. :)
#8 Captin Hook
Captin Hook
    New User
  • PipPipPip
  • 78 posts
  • Spokane
Posted 18 March 2014 - 11:24 PM
Thanks for the heads up that was my next call over to delta and see if they have any ideas or pointers. After that is to find a machinist.
