ea82 rear strut retrofits
5 replies to this topic
#1 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 14 March 2014 - 10:29 PM
Is it possible that 00 and up legacy and 05 and up impreza shock style rear strut will retrofit into an ea82 with ea82 top mount and coilover springs?
I speculate this could work, but have no parts to mock up. Has anyone done this?
I would like to know that late model struts will retrofit, and if there is a kyb agx II strut for the application.
#2 nncoolg
nncoolg
    USMB Regular
  • 183 posts
  • Gold Coast, Australia
Posted 15 March 2014 - 12:10 AM
this may help point you in the right direction : http://www.subaruxt....e build#p138384
Edited by nncoolg, 15 March 2014 - 12:10 AM.
#3 el_freddo
el_freddo
    Eat, Live, Breath Subaru
  • 694 posts
  • Lancefield, Vic, Aust.
Posted 15 March 2014 - 04:28 AM
I've often thought about the Gen3/4 rear strut/shock fitting into the rear of the L series - I'm sure it could work, but the double rubber setup on the L series shock could be an issue.
I reckon the load rating on that spring and strut/shock would be higher with the heavier body of the Gen3/4.  Just need to find a set of second hand units to have a play with...
Cheers
Bennie
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,810 posts
  • Saginaw, MN
Posted 15 March 2014 - 09:59 AM
I test-fitted it once. It's close, but not great. WJM actually ran them years ago. Then I tried some Miata ones that were closer, but still were not designed for the bushing in the upper mount. WJM and I had the same idea, and same result. Remove the bushing......and broken shock rods.
Then I found a later model Miata which did have a bushing in the upper mount, and fit in place of the EA82 rears almost perfectly.
All of these options use different diameter springs than EA82s, so you'll have to get creative with spring perches, or use coilover sleeves (what I did...)
#5 Ibreakstuff
Ibreakstuff
    USMB Regular
  • 533 posts
  • NorCal Transplant
Posted 15 March 2014 - 04:04 PM
They work but DO NOT SOLID MOUNT THE TOP HATS. Ask me how I know... Keep both upper and lower top hat bushings to avoid breaking the shock shaft. You need a bushing/sleeve for the bottom bolt too.
See this post:
http://www.ultimates...gon-shocks-wtf/
#6 Ibreakstuff
Ibreakstuff
    USMB Regular
  • 533 posts
  • NorCal Transplant
Posted 15 March 2014 - 04:06 PM
I'll add to this, my cut wagon springs and gr2 kyb shocks performed pretty damn well in my first 3 door. Not comparable to coilovers, but probably as good or better than the legacy shocks.
