1988 Subaru GL Transmission Knock
transmission
6 replies to this topic
#1 carpyblue
carpyblue
    New User
  • PipPip
  • 16 posts
  • Spokane
Posted 17 March 2014 - 11:15 AM
Anyway, at least I believe it is a knock. At first I thought it was Piston Slap in the motor. A Subaru Mechanic told me piston slap was not common with these motors.   It is a 1988 Subaru GL 4 wheel drive wagon.  It has the selective 4 wheel drive. It is not full time 4 wheel drive. The knock is most noticeable when cold and then gets better as it warms up. This happens when it is in 2 wheel drive.   When I shift it into 4 wheel drive the knock disappears completely. Yes, I checked the oil and it is not discolored and does not leak.   Any ideas out there?
#2 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 17 March 2014 - 11:24 AM
Drive shaft U joints on front half of rear drive shaft
#3 rdweninger
rdweninger
    USMB Regular Nut
  • 790 posts
  • Tillamook, OR
Posted 17 March 2014 - 12:18 PM
Dang, Ivan... you're good.
  Ivan, can you explain why the knock goes away when it is IN 4wd?  The rear drive shaft does still spin when in 2wd.
Carpyblue... you let us know if/when you replace the u-joint.
#4 suprjohn
suprjohn
    Eat, Live, Breath Subaru
  • 260 posts
  • North Platte, NE
Posted 17 March 2014 - 01:35 PM
If the shaft is under a load, it might bind up enough to quiet the knock.
Is the knock only present while in motion, or does it occur when stopped as well?
John
#5 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 18 March 2014 - 09:55 AM
In 2wd the shaft is non loaded so it turns with diff but not with 4x4 gears so you can hear the shaft rocking on Ujoint when in 4x4 the shaft is loaded by 4x4 gears keeping Ujiont under constant load making noise stop.
#6 carpyblue
carpyblue
    New User
  • PipPip
  • 16 posts
  • Spokane
Posted 23 April 2014 - 12:12 PM
I will check the u joint. The knock only happens when it is in motion and in 2 wheel drive under load. No knock when it is stopped or coasting. I forgot I posted this, too many other things going on here, I appreciate the answers, thank you.
#7 SmashedGlass
SmashedGlass
  • 669 posts
  • From CO, stuck in FL
Posted 23 April 2014 - 03:57 PM
Tis, indeed, your u-joints. I went through this same problem just before moving from Colorado to yuc....I mean loverly Florida. Only mine was more like someone swinging a hammer at my tranny when I would put her into reverse, lol. My joints were shot, bought new ones from Advance and then found a nearby driveline shop to install them. I think I paid $50 to have the old pressed out, new ones put in, lubed, and the whole assembly balanced, even. Dead quiet now.
