aftermarket lights mod
9 replies to this topic
#1 Navybratboy
Navybratboy
    Advanced Member
  • PipPipPip
  • 36 posts
  • spirit lake, ID
Posted 18 March 2014 - 01:12 AM
does any one know how these can be put on an 83 brat? http://www.ebay.com/itm/330945918261  i was thinking about putting them on mine and was woundering if any one has done it?
#2 Navybratboy
Navybratboy
    Advanced Member
  • PipPipPip
  • 36 posts
  • spirit lake, ID
Posted 18 March 2014 - 01:13 AM
also im having issues getting my low beams to work my highs work just fine just the lows wont turn on?
#3 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,237 posts
  • Puyallup
Posted 18 March 2014 - 08:28 PM
Yep, those are the ones. A couple people here have done it and it's on my list.
#4 wagonist
wagonist
    User Awaiting Email Confirmation
  • 909 posts
  • Sydney, Australia
Posted 19 March 2014 - 06:53 PM
Sorry to highjack, but that sounds more like the headlight switch, rather than the lights themselves. The contacts get worn or dirty over time.
#5 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 20 March 2014 - 08:30 PM
It is not the switch.. Go to Daniel Stern's site the wiring has to be changed around..  I had the same problem with my hatch a few years ago.  While on the subject on the same site you can get more info for making headlight relays.. I cannot emphasize this enough they are worth every minute and curse word you spend/ utter while putting it together.  I feel like it doubled the light output just by eliminating voltage drop.
Edited by Mykeys Toy, 20 March 2014 - 08:31 PM.
#6 Navybratboy
Navybratboy
    Advanced Member
  • PipPipPip
  • 36 posts
  • spirit lake, ID
Posted 07 April 2014 - 02:37 AM
Oh I figured it out when I was searching around the contacts with in the wire harness connection to the headlights was corroded and all that jazz. So i am going to keep using that connection till it stop working then splice that one wire on both sides and add its own connection of some sort.
To-skishop69
So a few people have done this mod to there lights? You would happen to know how they install or things along those lines I still need to buy those I'm just in sure how they connect to get the led "halo/ angel eye" to work other than my guess of 1) instal a switch to activate them or 2) splice the power lines to the markers and connect them with like a bullet connecter?
To-all
Any one have the skills or know how or know who to fix fabricate and full drivers front fender for the brat or know what other models have interchangeable body panels with an 83 brat and know a place that I could contact to ether get a used one or make it cause I need to fix mine it make the car look really bad with it all f***ed up.
#7 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 08 April 2014 - 07:03 PM
I recommend using a relay and a switch but you can also tap them into your running light  or your blinkers (still through the relay)
Any panels from a gen 2 car with the same headlights will work the common years are 1980-1984 however there are some brats till 87 and hatches till 89.
Mike
#8 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
  • Englewood Colorado
Posted 08 April 2014 - 08:10 PM
Those lights make me feel funny in the pants...
#9 wagonist
wagonist
  • 909 posts
  • Sydney, Australia
Posted 08 April 2014 - 09:43 PM
I'm glad that you found the problem, and I completely agree with the comments about adding relays. That makes a heck of a difference. DO IT :P
Sorry if you think this is a "flame": Mykeys Toy, but to definitively say "it is not (in this case) the switch" is a really bad thing to tell someone else over the internet (especially a forum). Unless you've got some inside knowledge (eg you guys know each other & have spoken off the forum), how could you tell from the limited description that the switch wasn't the problem? I couldn't.
It has been the problem on one of my previous cars, and so I suggested it be investigated. I didn't say it was the problem in this case, just could be.
A lot of newbies read & search here, because the info is so good & everyone is so willing to help. So making a definitive answer about something is a bit frought with providing misinformation. Don't rule out something just because something different happened to you.
Unfortunately, our cars are old and so exhibit a multitude of problems... :wacko:
#10 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 09 April 2014 - 11:08 PM
No flames necessary I understand what your saying.. I was under the impression ( though I have never looked )  that there is a separate relay aside from the switch for the headlights.  That said the OP mentioned that they come on just not the way he would like and so I did assume that the switch is not the culprit in this situation.  Then  I thought that maybe running a relay as a trigger off the factory light plugs with larger wire to the lights from the relay which would minimize voltage drop for another 30 years.
Edited by Mykeys Toy, 09 April 2014 - 11:08 PM.
