GL won't start after girlfriend added too much oil...
56 replies to this topic
#1 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 10:33 AM
So my girlfriend added too much oil to the car yesterday and then tried to start it. It would not start. What is my course of action here and what are the chances that the engine is screwed? I'm guessing drain the oil completely and refill to proper level but why won't it turn over?
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 02 April 2014 - 10:43 AM
Maybe it sucked some up in the PCV. oil capacity should be about 4.5 qts with filter.
Sp the engine is hydro locked, or just won't start? maybe the cylinders are full of oil. correct the oil level, reove the spark plugs and the engine should crank, pushing out any oil that may be in the cyliders. prepare for a mess, place some rags over the spark plug holes. maybe spray some carb cleaner in the cylinders to wash out the oil, clean the plugs or replace them, start the car, and let the oil burn off. Once it is running again, perhaps sea foam it to get any oil out of the intake runners
#3 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 12:08 PM
Sorry, it turns over but makes a high pitch whirring sound. I'm assuming hydrolock but I'm not sure. I plan on following your instructions this evening after work. My only question, seeing as I am a certified noob, is where/how does one sea foam?
#4 ferox
ferox
    King of the Echo People
  • 943 posts
  • Portland, Oregon
Posted 02 April 2014 - 01:43 PM
If the engine was hydrolocked it wouldn't turn over, so that is not your issue.  I assume in your original post you meant that it won't start.  Seafoam can be used many ways.  The instructions are pretty easy to follow.  What year is your GL?
#5 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 02:24 PM
It is a 1987 GL 4 door wagon.
#6 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 02:29 PM
So I have drained the oil and am going to fill it to the proper level. I removed one of the spark plugs and it was dry as a bone. Would I notice oil on the plug if it were filled to that level?
#7 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 03:28 PM
I've added the proper amount of oil and tried to start it but to no avail. It is still making the high pitched whirring sound when I try to start it.. As I asked above...would I see oil on the plugs if the oil was filled to that level?
#8 colemanapp
colemanapp
    USMB is life!
  • 139 posts
  • St. Louis, MO
Posted 02 April 2014 - 03:43 PM
Not sure but would a broken timing belt make a high pitch whirring sound cause the cranks not turning valves, thus the motors turning over quicker? Not that the oil level would have anything to do with that but...
#9 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 04:43 PM
Excellent point...I'll check it out.
#10 yblocker
yblocker
    Advanced Member
  • PipPipPip
  • 69 posts
  • Oakland,CA
Posted 02 April 2014 - 04:46 PM
The sound would be uneven though- with at least one cylinder with closed valves making compression.
Remove the distributor cap to watch the rotor turn as you crank or just pull all 4 plugs like was previously suggested and then crank.
You need to remove all 4 plugs because the other side of the engine could be the side with the busted belt if that's what it is.  You should hear air pumping out from each plug hole while cranking.
Are you sure the sound is coincidentally just the noise of the starter motor not engaging?
#11 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 04:52 PM
I removed all four plugs and turned the key. It just made the same noise. It isn't a continuous whirring. It stops for a split second and then continues like it's not engaging, but it has never sounded like this before when it didn't want to start.
#12 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 04:56 PM
When the battery had died before and it didn't want to start it made the usual chugchugchug sound. But now it's more like a wheeeeeeeclick wheeeeeeclick...if that helps you to visualize it at all.
#13 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 05:05 PM
The belts are all in great condition and spin when I turn the key to start it. Just checked.
#14 silverback
silverback
    New User
  • 150 posts
  • Seattle
Posted 02 April 2014 - 05:10 PM
Sounds like a starter motor problem.  If you know that the engine rotates, check the oil pressure. If you have a broken timing belt on the passenger side, the oil pump does not rotate. Zero oil pressure on the gauge and the engine cranks over with little resistance.  Take off the plastic timing belt covers and lose them.
Where did your girlfriend put the oil----exactly????
#15 silverback
silverback
    New User
  • 150 posts
  • Seattle
Posted 02 April 2014 - 05:17 PM
Remove the distibutor cap and inspect. Look for wear and moisture.
#16 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 05:21 PM
She put the oil in the correct place. That was the first question I asked.
#17 wagonist
wagonist
    User Awaiting Email Confirmation
  • 987 posts
  • Sydney, Australia
Posted 02 April 2014 - 05:28 PM
Is this her telling you she put it in the correct place, or she showed you where she put it? ;)
Makes a difference. Don't forget, she didn't know that oyu could put too much oil in.
#18 chompy
chompy
    Member
  • PipPip
  • 27 posts
  • Portland
I second the starter problem just based on your wheeeeeeclick description, although you are saying you have physically seen the belts move when it is being turned over?
#19 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 05:30 PM
She pointed to the oil cap.
#20 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 05:31 PM
I watched the belts move from the driver's seat and marked them to make sure they had moved.
#21 chompy
chompy
    Member
  • PipPip
  • 27 posts
  • Portland
Posted 02 April 2014 - 05:42 PM
Do you have a timing light to see if it is getting spark?  You can also pull a plug. Attach it to the plug wire and grab the plug with a nice pair of INSULATED pliers and slightly ground it on the block while someone else turns the car over.  You should see a nice spark.  You need to start from the beginning and slowly work your way through the system until the problem is isolated.  Spark and fuel...
Edited by chompy, 02 April 2014 - 05:43 PM.
#22 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 02 April 2014 - 06:06 PM
Check for spark. Lay a spark plug wire down by something metal, turn the key, watch for it to arc. If spark, check for fuel. Spray some starting fluid in there and see if it fires up briefly.
#23 l75eya
l75eya
  • 2,371 posts
  • Hoboken, NJ
Posted 02 April 2014 - 06:07 PM
Fuel injected or carburetor? If carb spray right into the carb, if fi. Spray into air intake. Clamp airbox closed before trying to start it just in case it backfires.
#24 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 06:10 PM
I recorded the sound it's making in case anyone would like to hear it.
It's here:
http://soundcloud.com/malcontent13/
87-subaru-gl-starting-issues
#25 Malcontent
Malcontent
    New User
  • PipPip
  • 21 posts
  • Humboldt
Posted 02 April 2014 - 06:11 PM
I will check for spark in a bit.
Edited by Malcontent, 02 April 2014 - 06:11 PM.
