pa_trick Posted April 5, 2014 Share Posted April 5, 2014 I am about to pull the Ej22 out of my '92 legacy wagon and give it the new timing belt, water pump and cam seals et al. I am looking for two things: 1. a good set of step-by-step instrutions for this process. 2. advice on other things to check/replace while I have it out of the car. Thanks in advance Quote Link to comment Share on other sites More sharing options...
heartless Posted April 5, 2014 Share Posted April 5, 2014 (edited) if you are pulling the motor (not a necessary step for a timing job, but does give easier access) then reseal the rear oil separator plate (use an anarobic sealant or ultra grey), and replace the o-rings on the rear cam seals as well. 92 should have the cast alloy plate, but if it is plastic then you will want to replace it with a stamped steel one, which will also require new screws. unless it is obviously leaking really badly, leave the rear main seal alone. for instructions try this: http://www.ultimatesubaru.org/forum/topic/74256-ej22-timing-belt-change/ alternatively, a video by our own Miles Fox: Edited April 5, 2014 by heartless Quote Link to comment Share on other sites More sharing options...
