2" lift suggestions on a 2012 subaru outback
I am inquiring about suggestions for lifting a 2012 subaru outback.  I live near the beach and clearance is important, as the car sits its is going to get bogged down due to trucks making the ruts and softening the sand.  I am not intending to kill the car on the beach, just access good surf breaks. My thoughts are:  what's  the best bang for the buck on lifting and then going to largest most balloonest tires that can fit on a slightly bigger rim.  Not looking to make a monster subaru, just enought to sneak by. All positive and negative suggestions are welcome.. Thanks...
Thanks, just started to play with the idea.    First time i peaked under the car, for this, is today, the rear, i think i can have a riser made for the lower end of the strut to mount into.  Simple steel fabrication or if there is a prefab, makes life easier...
I will investigate some more for the front  any web sites to look at or pointing in a good direction, would be great..
Will do more research....   I have to say, as i never had a subaru and always had a truck, they have designed the underneath of the car amazing for clearance...
Thanks
