Hi, Im new and have a tire compatibility question
2 replies to this topic
#1 jamesstoll1
jamesstoll1
    Newbie
  • Pip
  • 3 posts
  • Boise
Posted 14 April 2014 - 05:48 PM
I have a 2007 Subaru Outback with tires that measure 225/55R17.  A guy in my town is selling the new tires off of a 2014 Forester that measure 225/60R17.  Will the Forester tires fit if I purchase?
Thank you in advance for any assistance you can provide.
Best regards,
James
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 14 April 2014 - 09:05 PM
It will fit on the rim. the wheel will be roughly the same width, with a slightly taller sidewall.
the 225 is width in millimeters, and the 50 or 60 is the percent of that with in sidewall height; an aspect ratio.
What you want to be sure of is fitment between the tire and the strut spring perch.
This should fit, as the tires will only be slightly larger in diameter. within an inch. If you have more than an inch between your current wheels and the strut perch, go for it.
According to the tire size calculator
Tire Size Comparison
Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
225/60-17         5.3in  13.8in    27.6in         86.8in        730        0.0%
225/50-17         4.4in  12.9in    25.9in         81.2in        780       -6.4%
#3 grossgary
grossgary
    Elite Master of the Subaru
  • 21,810 posts
  • Midatlantic
Posted 15 April 2014 - 03:53 AM
definitely fit the rims.
you'll want to see if they'll clear the vehicle - strut bottoms up front are tightest space i've run into when installing tires too big.
