bratman18 Posted April 18, 2014 Share Posted April 18, 2014 What have people done to adapt ea power steering lines to the ej pump. I have the return cut and just have the hose and clamps attached, but what about the high pressure side? Is there a certain flare tool that can make that type of flare for the fitting that goes into the pump? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2014 Share Posted April 18, 2014 last resort - graft EA rack side lines onto a EJ pump side lines? cut metal and connect them with hose or weld together? these help at all: Cleanest option is to use EJ lines from pump to crossmember, and EA lines from crossmember to the rack. http://www.ultimatesubaru.org/forum/topic/101283-ejea-power-steering/ i used an early legacy PS pump (1990-1994 i believe) with the EA rack and EA hardlines. http://www.ultimatesubaru.org/forum/topic/48501-for-those-with-ej-conversions/ Quote Link to comment Share on other sites More sharing options...
bratman18 Posted April 18, 2014 Author Share Posted April 18, 2014 I suppose they could be tight welded together. Not sure. The high pressure side has too much pressure to just use a hose and clamps from what I'm told. I'm not sure how you'd use ej lines from the pump to cross member where they come off the cross member in completely different ways. I did look at that option. And as for ea lines bolting right up, I don't know how. Again, they have completely different bends and routing for that to happen. I tried. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted April 18, 2014 Share Posted April 18, 2014 (edited) I cut the flexible sections off of EJ pump's lines leaving only the metal sections at the pump. I silver soldered some old brass fittings on to those EJ lines. Standard EA PS lines bolt right up now. Future repairs will just take stock EA P/S lines from now on. I have several thousand miles on this setup and it works great. I will be happy to snap a quick picture if you keep hounding me about it This is on my 1983 GL FT/4WD Wagon with an EJ22 and power steering. All the hard and soft lines after the pump are stock EA. The lines at the cross-member are a little tight but it fits like a glove. You can sort of see some of it in these pics. I'll snap a quick picture of the modified lines up top this weekend if I get time. Edited April 18, 2014 by Crazyeights Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 18, 2014 Share Posted April 18, 2014 (edited) Grab some EJ lines. The connector at the junction down on the crossmember are the same... Hook up the EJ hardlines to the EA82 lines at tha connector.....takes a little bending and unbolt from the bracket but it works great. Or even easier just bend the EA82 lines up near the pump and install them into the EJ pump......Done. I've got XT turbo hardlines bent a bit to fit in my 86 GL w/EJ22 EA81 power steering doesn't have the same connectors so crazyeights suggestion would be good for ea81setup. Edited April 18, 2014 by Gloyale 1 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 18, 2014 Share Posted April 18, 2014 I'm not sure how you'd use ej lines from the pump to cross member where they come off the cross member in completely different ways. I did look at that option. And as for ea lines bolting right up, I don't know how. Again, they have completely different bends and routing for that to happen. I tried. You gotta bend the lines a bit.....It's okay just be gentle....they will bend just don't totally kink them. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 18, 2014 Share Posted April 18, 2014 mine has an xt6 steering rack connected to the ej pump, no mods other than bending the bracket Quote Link to comment Share on other sites More sharing options...
bratman18 Posted April 18, 2014 Author Share Posted April 18, 2014 Alright, thanks guys. I guess I'll have to look again next time I work on it. It didn't look like swapping the lines would work at all, as that was the original plan. But I'll investigate further. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted April 21, 2014 Author Share Posted April 21, 2014 Well I was able to use the ej lines. A little twisting and bending and they did go together. Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
Prwa101 Posted April 21, 2014 Share Posted April 21, 2014 Left side is ej right side is ea. I made a sleeve an welded them together. That's the best you can do without spending 200$ for custom set. https://fbcdn-photos-a-a.akamaihd.net/hphotos-ak-prn1/t1.0-0/554931_4975232497621_859111450_n.jpg This image should work... Quote Link to comment Share on other sites More sharing options...
presslab Posted April 24, 2014 Share Posted April 24, 2014 I have used a steel compression fitting to splice the high pressure line. I bought it from McMaster-Carr. 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted April 25, 2014 Share Posted April 25, 2014 These are all great solutions. Thanks for the EA82 <--> EJ22 ideas. I have two of those swaps going right now. Quote Link to comment Share on other sites More sharing options...
kirzick Posted May 5, 2014 Share Posted May 5, 2014 Can you attach the ea pump to the ej and just use that? My ej's pump is gone. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted May 5, 2014 Author Share Posted May 5, 2014 Can you attach the ea pump to the ej and just use that? My ej's pump is gone. Maybe with a bunch of fabrication. But the EA pump won't easily bolt onto the ej motor. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 5, 2014 Share Posted May 5, 2014 Maybe with a bunch of fabrication. But the EA pump won't easily bolt onto the ej motor. Actually......if you get a PS bracket from a 90-91 Legacy.........the pump Old GL pump will bolt straight into that bracket. Gotta change the pulleys...but otherwise it does fit.......... It still moves the pump relative to were it would be on an EA.....so youd still have to bend the EA lines some. It's really the same as just using EA lines all the way to an EJ pump.......which works too.... 100 ways to skin this cat. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted May 5, 2014 Author Share Posted May 5, 2014 No kidding. It looked too different to me, but subarus are legos! I know mine works much nicer with the ej pump than the ea pump! Quote Link to comment Share on other sites More sharing options...
kirzick Posted May 5, 2014 Share Posted May 5, 2014 Cool thanks guys, ill update with my findings. Quote Link to comment Share on other sites More sharing options...
