1990 loyal Fuel pump fuse
fuse fuel pump loyal
3 replies to this topic
#1 kirzick
kirzick
    USMB is life!
  • 148 posts
  • olympia washington
Posted 18 April 2014 - 07:10 PM
hey guys,
I just bought a new loyale. I cant get it to start. the fuel pump is only getting 1.00 at the fuel pump when cranking, and nothing at on. Would this problem be in the ignition switch? thanks
#2 heartless
heartless
    Do YOU Subaru?
  • 3,072 posts
  • North Central Wisconsin
Posted 18 April 2014 - 08:44 PM
you would get a better response to this inquiry in the older gen section - Loyale is considered "old Gen"
http://www.ultimates...-gldlxtloyales/
#3 kirzick
kirzick
    USMB is life!
  • 148 posts
Posted 20 April 2014 - 01:37 AM
Woops i read the section name wrong. Fixed it btw though i wacked the fuel pump with a wrench and it kicked on!  :D
#4 Cougar
Cougar
    Elite Master of the Subaru
  • 6,552 posts
  • Anchorage
Posted 20 April 2014 - 11:57 AM
For your reference, there are fusible links inside the plastic box mounted on the coolant resevoir incase weren't aware of that. They can develope loose connections at times and cause electrical outages.
Also tagged with one or more of these keywords: fuse, fuel, pump, loyal
