EA81 Bell housing Dimensions
hi,
 they are not just a flat plate type thing, it is precision fitted on dowel pins to the block, and the crankshaft  rear main seal is fitted into it as well, also it seals an inch or so of the rear of the oil pan on the bottom of it.   i think there is a gasket between it and the block  too but can't remember for sure.  it  definately closes off the rear of the block and is integral to it.    anyway point is, it's a lot more involved than the ea82 block plate bell houseing.   dimentions i can't help but someone might send you one to work with, should be plenty of them, ,  there are auto trans ones and manual trans ones , can't say if they are the same or not,, and there are 1.8 ea81 and 1.7 or 1.6 , ea71,  so be aware there are several variations perhaps.
Edited by ruparts
