AWD J3wman Posted April 22, 2014 Share Posted April 22, 2014 (edited) So I've been looking for a set of adapters in the aforementioned size, with little avail, just custom one off pieces that cost a ton. I was doing some thinking today and since I got a new job at a performance shop here in Minnesota called Modern Automotive Performance, I have many more resources to my disposal. One of the perks of the job is a machine shop, which I can make my own set at, Since most era correct wheels for my EA82 are 4x114, I was thinking 4x114.I was going to keep the hub ring size the stock size for simplicity, as far as materials my plan at the moment is to mill them out of aluminum and use some ARP extended wheel studs. Now I'm wondering if anyone else would be interested in these because after I make my set I'll have a blueprint and a prototype model to base off of. If I do make more than one set I was going to go with 4x114, instead of the usual 5x100 since there are more options in 4x114.Anyway, Would anyone be interested in a set of these if they were mass produced? MODS: if you want to move this feel free, I couldn't think of a better location Edited April 22, 2014 by AWD J3wman Quote Link to comment Share on other sites More sharing options...
mfa_mad_pig Posted April 22, 2014 Share Posted April 22, 2014 I'd be interested if the price was right. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted April 22, 2014 Share Posted April 22, 2014 Rather than adapters see if there is enough meat on the existing subaru hubs to mill them out to the new pattern. Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted April 22, 2014 Author Share Posted April 22, 2014 There might be, I was thinking adapters because they're easier to produce. I'm mentioning it to our fab r&d guy today at lunch. Quote Link to comment Share on other sites More sharing options...
wagonist Posted April 23, 2014 Share Posted April 23, 2014 (edited) And how far out are you expecting the tyres to sit? The offset is already pretty large on these cars. And you're going to need at least 20mm thickness on your adaptor to bolt them onto the hub, and then have the new studs retained... 99% of people I've seen either re-drill the standard hubs, or redrill 6x140 rims. Of course, if you could reproduce the factory part, that's a different story. And especially if you could do one for the rear to suit the disc brake rear end which has a spline then I'm sure you'll have a ready market for people wanting to convert to rear discs. The 4wd hub is the hardest thing to find (ie almost impossible). Edited April 23, 2014 by wagonist Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted April 23, 2014 Author Share Posted April 23, 2014 So you would rather see a 4WD set of hubs that are 4x114 than a set of spacers? Quote Link to comment Share on other sites More sharing options...
TallonX Posted April 23, 2014 Share Posted April 23, 2014 Or ready made 6x140 Spec milled and happy better than a luck shot with a drill bit lol Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted April 24, 2014 Author Share Posted April 24, 2014 Well I have a machine shop at my disposal 50 feet away from my desk so it wont be much of a luck shot Quote Link to comment Share on other sites More sharing options...
