What is this thing on the bottom of my engine?
23 replies to this topic
#1 Sandrion
Sandrion
    Advanced Member
  • PipPipPip
  • 77 posts
  • Grover, North Carolina
Posted 25 April 2014 - 07:20 AM
Was changing my oil for the second time since I bought this car, and noticed this little guy just sorta hanging out beside the filter, no wire in sight with a broken off end, but the ring terminal is still screwed into it. Took it out, cleaned it up and figured I would ask what the he!! it is. Here are some pictures of it all cleaned off, has 12v (volt I'm guessing,that pretty simple) and some other stuff stamped onto it. I figure it has something to do with the oil?  Here is where it screws into.
#2 colemanapp
colemanapp
    USMB is life!
  • 136 posts
  • St. Louis, MO
Posted 25 April 2014 - 07:23 AM
looks like the oil pressure sending unit.
#3 jono
jono
    Reader and writer
  • 1,690 posts
  • Southern Hemisphere - AUS
Posted 25 April 2014 - 07:24 AM
I hope you have guessed by now that it is the oil pressure gauge sender unit
#4 Discombobulated
Discombobulated
    Advanced Member
  • PipPipPip
  • 79 posts
  • Thornton, CO
Posted 25 April 2014 - 07:36 AM
Dang dude, wish everybody threw down pics like that on some questions, wonderful:)
As said above is correct, soooooo I take it your oil pressure on the dash doesn't work?
#5 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 25 April 2014 - 10:28 AM
I don't think you should run your motor without that in place.
#6 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 25 April 2014 - 11:12 AM
I am assuming his car has a Oil Light, not gauge..........Either a Loyale, or DL model.......And it's had an oil pump or whole engine swap at some point from a GL or Loyale w/gauge.
You can see up in the left corner is the Oil Light Switch..........It threads into a different port that the variable sender for the Gauge....which is the open hole below it.
#7 Sandrion
Sandrion
    Advanced Member
  • PipPipPip
  • 77 posts
Posted 25 April 2014 - 09:34 PM
I knew that it was something to do with the oil, although I was more wondering where the wire that connects to it is, or if it is gone (I still haven't been able to find it), how do I install/rig a new one into the car.
The other forums I am a member of often insist pictures of anything and everything, so I am in that habit. (It also helps alot).
My car is a Loyale 1993, less than 100k miles, original engine. Just someone has broken off that wire at some point another, or replaced the sending unit from another car maybe? I did indeed replace the unit before I finished off my oil change/service on the car. I wasn't attempting to drive it around without it, I'm not as dumb as I look.  B)
#8 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 25 April 2014 - 09:49 PM
Does your car have an oil pressure gauge???
If not.....your oil pump has been swapped........they didn't bother taking out the oild sender and finding a plug.........
they just installed the Oil switch for the light and left the sender sittin there with the remnants of it's wiring from whatever it came from hangin out.
There is nothing wrong......remove that thing and plug the hole with a 5/8ths plug.
#9 Sandrion
Sandrion
    Advanced Member
  • PipPipPip
  • 77 posts
Posted 25 April 2014 - 11:42 PM
No it doesn't have a guage, just the light. I will just leave the sending unit in it for now, its not hurting anything anyway. I was just curious in case it needed to be hooked up to something. Thanks for al the info!
Also, is it bad that the oil pump has been replaced?
#10 jono
jono
    Reader and writer
  • 1,690 posts
Posted 26 April 2014 - 03:33 AM
no oil gauge, yet you have a sender - lucky , especially if it still gives out a varying Ohm reading - just find a gauge. Other than someone swapping in an oil pump, maybe the whole engine was swapped in from something with a gauge.
#11 superpoo93
superpoo93
    New User
  • Gold Subscribers
  • 231 posts
  • las vegas
Posted 26 April 2014 - 08:59 AM
I changed mine out on my 93 Loyale after my timing belt broke. It happened just a couple of weeks after I bought it, since I did not know the history go the car and being paranoid.... And I was in there any way. My new oil pump came with both senders, not big deal it just fills the hole. Just leave it in place.
#12 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 26 April 2014 - 09:25 AM
I would plug it.
Those things fail and leak and are vulnerable to rocks offroad.
If you don't need it.......Get rid of it so it doens't break off and strand you or leak all you're oil out slowly either way a plug will be better, less risk.
#13 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 26 April 2014 - 10:47 AM
The wire for it is yellow and comes off the intake harness under th alternator and down the dipstick tube. it has a single spade terminl. you will find it and plug it in. that sender is for a gauge, so it is likely your engine or water pump has been swapped.
#14 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 26 April 2014 - 10:57 AM
He's got the light.....so the wire is likely already going to the switch.
What does this have to do with a water pump?  You mean oil pump???
Edited by Gloyale, 26 April 2014 - 10:58 AM.
#15 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 26 April 2014 - 04:37 PM
I meant oil pump.
#16 Sandrion
Sandrion
    Advanced Member
  • PipPipPip
  • 77 posts
Posted 26 April 2014 - 05:10 PM
Well I know that the motor hasn't been swapped. The oil pump has probably been swapped. But anyway, until I remember to get a plug, it will stay in place, doing nothing for me.
#17 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 27 April 2014 - 11:23 AM
How do you know????
Are you the first owner or got it from the 1st owner?
I hardly ever see an EA82 that's got it's original motor.  Just curious not arguing.
#18 Sandrion
Sandrion
    Advanced Member
  • PipPipPip
  • 77 posts
Posted 27 April 2014 - 08:34 PM
I bought it from the second owner, who received it from his dead grandmother, who was the first owner. It had 70k miles on it, has 88k now. I have alot of the service history from the PO. The motor shows the signs of being a low mileage motor, and the guy told me everything else about the car, good or bad. So I'm banking on it being an original.
#19 wagonist
wagonist
    User Awaiting Email Confirmation
  • 987 posts
  • Sydney, Australia
Posted 27 April 2014 - 09:44 PM
Score, I reckon. The gauge is a lot more useful than the light. The light should have a $ sign on it, cos once it goes on, something major has usually happened.
Try to find yourself a cluster with the oil pressure gauge in it. It should plug straight in if you've already got a cluster with the tacho.
Move the wire from the oil pressure light to the sender instead.
Then find the wire in the dash that goes to the oil pressure light (below the cluster), and extend that to the correct pin on the back of the cluster.
Presto, you now have a working factory oil pressure gauge.
#20 Subaruist
Subaruist
    Subaru Fanatic!
  • Banned
  • 376 posts
  • Medford, Oregon
Posted 01 May 2014 - 06:17 PM
Why that's the Catastrophic Converter!  ( Or the Q-36 Space modulator ) I'd know that anywhere! If you drive without it you can slip into another dimension, where all those other Subarus have disappeared to over the years!
#21 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 02 May 2014 - 10:50 AM
A loyale with an oil light and not a gauge..? THAT is the real mystery...
#22 Gloyale
Gloyale
    It's a sickness
  • 10,656 posts
  • Corvallis, OR PNW
Posted 02 May 2014 - 11:14 AM
Nah....there were lots like that.....espescially after 92.....
Loyales have alot similarities with the old DL models.
#23 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 03 May 2014 - 10:06 PM
You know... that seems plausible... All 4 clusters I have here are from 90-92 Loyales.. hahaha
#24 wagonist
wagonist
  • 987 posts
  • Sydney, Australia
Posted 04 May 2014 - 09:17 AM
It's just retro fitting the gauge to a car that just had the light means installing an extra wire through the dahs loom, through the car loom, and through the engine loom...
Easier to just use what's there :P
