Thread size - crankshaft bolt - legacy 2.5L EJ25D
ej25d 2.5L crankshaft bolt thread
1 reply to this topic
#1 kevinrse
kevinrse
    Advanced Member
  • PipPipPip
  • 37 posts
  • Blacksburg, Virginia
Posted 05 May 2014 - 05:27 PM
I need to clean up the threads inside my crankshaft.
Made a mistake using a puller; got a small piece of metal jammed in the crankshaft end but fished it out with some epoxy. I want to clean the threads up before putting it back together.
I am measuring thread spec using my crankshaft bolt and calipers. By my measurements major thread diameter = 12.8 mm, thread pitch = 1.5 mm (averaged along 15 threads). Should I assume that the proper tap size = M13x1.5?  (The reason I come here to verify is because M13 isn't a common size, so I want to make sure I'm right before I order the tap).
Thanks.
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 05 May 2014 - 08:46 PM
I want to say its M12x1.5
Take the bolt to a Fastenal store, or any store that sells specialty hardware, and they can measure it.
Also tagged with one or more of these keywords: ej25d, 2.5L, crankshaft, bolt, thread
