help me find the gremlins
6 replies to this topic
#1 rete
rete
    Newbie
  • Pip
  • 4 posts
  • south lake tahoe,ca
Posted 18 May 2014 - 10:34 PM
Hi, Im new to subaru's and new to driving a manual too,(never going back ;) ).I have a 1997 subaru impreza outback that needs a little TLC and I  need some ideas about what and how to fix the problem that my car is experiencing. There is a rubber on rubber squeaking sound from the front left wheel when I turn left and speeds of 40 mph or less. I have replaced the inner and outer tie rods,front left brake caliper ,rotors and pads on the front left and right ,struts,and replaced the bad hub,bad wheel bearings with a used hub. New serp belt and powersteering belt?(two belts at the front) Again, its only on the front left and only noticeable at speeds under 40 mph and when I make any kind of left turn.Alignment is fine,tires good.Oh yeah,its only after the car has been driven for a fewmiles.What could it be????
Edited by rete, 18 May 2014 - 10:48 PM.
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 19 May 2014 - 10:10 AM
Does it sound like a tire screaching or is it more like the farty kinda noise that leather seats make when you slide across them?
#3 rete
rete
    Newbie
  • Pip
  • 4 posts
Posted 24 May 2014 - 02:02 PM
#4 rete
rete
    Newbie
  • Pip
  • 4 posts
Posted 24 May 2014 - 02:03 PM
It's more like a rotating rubbery chirping
#5 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
Posted 25 May 2014 - 07:39 AM
Possible your power steering belt is a little loose.
There isn't anything in the wheel area that would squeak like that.
#6 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,956 posts
  • Texas
Posted 25 May 2014 - 10:17 AM
dunno why it would be directionally biased, but maybe the crank pulley is starting to separate/wobble?
could the strut mount be squeaking?
maybe debris behind brake dust shield ?
do you mean there's squeaking AS you turn the wheel? or, DURING the turn as the car moves with the wheels turned?
Edited by 1 Lucky Texan, 25 May 2014 - 10:18 AM.
#7 rete
rete
    Newbie
  • Pip
  • 4 posts
Posted 18 June 2014 - 11:09 PM
Replaced the front left cv axle with a brand new one.I have used forester struts on the front passenger and driver side.The rubber squeaking and chirping is gone,but what remains is a tick tock click sound from the front left wheel area at under 3rpms.Im not sure if it goes away after 3 rpms or if my muffler noise drowns it out at higher speeds.(and much more noticable as your driving rather than walking alongside) ????????????????/
Edited by rete, 19 June 2014 - 12:48 AM.
