EA82T dies when gas gauge moves :/
ea82t wtf
8 replies to this topic
#1 BoostedBoxer421
BoostedBoxer421
    USMB is life!
  • 187 posts
  • Newport, WA
Posted 20 May 2014 - 10:37 AM
so recently ive been driving my turbo wagon daily, and now whenever i put gas into it or go up a steep hill and the gas gauge moves it dies
when it dies i know its something electrical because i cant pop start it and the tach wont move when starter is running, but it'll start after a few minutes and i know when its about to start because the tach starts to jump when trying to start it
ive never heard of anything like this before, so i was hoping someone may have had the same problem before and might know what to do. has been really frustrating lately :banghead:
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 20 May 2014 - 01:17 PM
The first place I suggest you for the trouble is the fusible links located in the plastic box mounted on the coolant reservoir. Check for loose connections. Some folks have found bad connections on the bottom side of the panel also. If that area is okay then the ignition switch may be the next best suspect. Check to see if the dash fuses are getting power when the trouble happens. If they aren't then the trouble is between the fusible links and the ignition switch wiring.
The fuel pump may be getting weak since going up hills is a problem. If that problem still happens after you fix the connection problem I suggest you replace the pump.
#3 BoostedBoxer421
BoostedBoxer421
    USMB is life!
  • 187 posts
  • Newport, WA
Posted 20 May 2014 - 07:20 PM
Fuel pump is brand new, so I'll have to check power at fuses when it does die
And its not the going up hill part, it does if I go down hill and stop too, or even if I accelerate really hard and when the gas gauge moves it dies
I can pretty much count on it dying every time I get gas now, like it'll fire up for a second and die at the gas pump
#4 jono
jono
    Reader and writer
  • 1,861 posts
  • Southern Hemisphere - AUS
Posted 21 May 2014 - 03:28 AM
if you are led to believe it is as a result of the depth gauge moving - disconnect gauge sender wire at tank sender, see if things change ?
#5 BoostedBoxer421
BoostedBoxer421
    USMB is life!
  • 187 posts
  • Newport, WA
Posted 21 May 2014 - 10:11 AM
ok, ill see how that works soon as i can get to it. and im thinkin that because its as soon as i get gas every time now, right when the gas gauge moves about 1/8 inch it just cuts power. not all power, just ignition, everything else still works fine. the tach doesnt move when it happens, i just keep turnin the key and as soon as i see the tach jump a lil bit i just hold the key on and it fires right up
#6 Dee2
Dee2
    USMB Regular
  • 630 posts
  • US
Posted 21 May 2014 - 01:05 PM
When it dies is it sudden ?  If so, then indeed it is likely electrical related.
If it dies slowly, doing a hurt dance, then it is likely a fuel related problem.  Checking the sending unit connection is a great idea of where to start looking.
Edited by Dee2, 21 May 2014 - 01:05 PM.
#7 robm
robm
    Subaru Nut
  • 933 posts
  • Terrace, B.C.
Posted 21 May 2014 - 01:17 PM
Have the engine running when you disconnect the fuel sender.  Can't hurt, and if it stops when you play with it, then you know it is somehow (weirdly) related.
#8 BoostedBoxer421
BoostedBoxer421
    USMB is life!
  • 187 posts
  • Newport, WA
Posted 21 May 2014 - 02:01 PM
yeah its just an instant power cut when it does it. im gonna try disconnecting the sending unit while running next
#9 BoostedBoxer421
BoostedBoxer421
    USMB is life!
  • 187 posts
  • Newport, WA
Posted 29 May 2014 - 01:17 AM
So... I have no idea why it would die every time I got gas, but my problem was from my crank angle sensor failing
