timn29 Posted May 7, 2004 Share Posted May 7, 2004 I am about to change the AT filter and fluid in my '98 OBW and would ask the collective wisdom of the group their opinion on the best filter and fluid to replace the old. Any thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
blitz Posted May 7, 2004 Share Posted May 7, 2004 IMHO, use a dealer tranny filter. It's not likely that you'd ever have to replace it more than once during the life of the vehicle unless you rack up some ungodly amount of miles, or tow constantly and heavy. The factory filter was installed so tightly on my '02 that I was almost resigned to thinking it was impossible to remove. Also, once the filter is loosed or punctured, a lot of fluid comes pouring out and continues to trickle out (of the valve body) for over an hour, so have a big, wide drain pan and lots of towels handy. My manual indicates that any Dexron III fluid is acceptable but doublecheck your own before proceeding. I've been using M1 tranny fluid with favorable results. Quote Link to comment Share on other sites More sharing options...
WAWalker Posted May 7, 2004 Share Posted May 7, 2004 You don't need to change the filter. Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 7, 2004 Author Share Posted May 7, 2004 interesting comments, because the servicemen at the dealer recommends I bring in my '98 Outback wagon for the 120,000 mi. tranny service with which they'll replace the fluid and filter. I also ask because I told them about my "chattering" turns (viscous couplers going bad?) and they told me the tranny service may fix that too. What to do? thanks Quote Link to comment Share on other sites More sharing options...
howards11 Posted May 7, 2004 Share Posted May 7, 2004 I believe you will not find another brand AT filter for your OBW. You are stuck with Subaru which really isn't bad either. ~Howard Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 11, 2004 Author Share Posted May 11, 2004 Check this out... I went to the dealer to pick-up my replacement AT dipstick they lost and I asked about the AT filter, I was told '98 Outbacks don't have a servicable filter per say, but more like metal screens that are simply flushed when the AT system is flushed which is recommended at the AT service mileage (every 3,000 or so). So it looks like I'll be getting my AT system flushed. Thanks. Quote Link to comment Share on other sites More sharing options...
WAWalker Posted May 11, 2004 Share Posted May 11, 2004 Thats going to get pretty spending having a trans flush every 3,000 miles. Sure they didn't say 30,000? Subarus recomended trans service during scheduled maintanence is a drain and refill every 30,000, unless you tow or drive under very extreme conditions. Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 11, 2004 Author Share Posted May 11, 2004 Sorry, I think you're right now that I think about it. BTW would anyone know the amount of ATF I would need to replace once I do a drain and refill? Thanks WAWalker! Quote Link to comment Share on other sites More sharing options...
99obw Posted May 12, 2004 Share Posted May 12, 2004 I usually get about 5 quarts out of it. The subaru part number of the external filter is 38325AA032. It sounds like your car doesn't have an external filter like the '99, I'm not sure. Quote Link to comment Share on other sites More sharing options...
JEGIII Posted May 12, 2004 Share Posted May 12, 2004 What years have the external filter? I have to admit I haven't looked for one under mine. Are they fairly obvious, or well hidden? Quote Link to comment Share on other sites More sharing options...
corsair Posted May 15, 2004 Share Posted May 15, 2004 I am about to change the AT filter and fluid in my '98 OBW and would ask the collective wisdom of the group their opinion on the best filter and fluid to replace the old. Any thoughts? Thanks The replacement spin-on trans filter (if you have the spin-on filter on the left side) is a Hastings TF-170 which has the anti-drainback and wire mesh bypass valve in the center of the filter (replacing the Subaru part number 38325AA032 and 38325KA000). Also check here: http://catalog.hastingsfilters.com/ or here: http://www.wixfilters.com/filterlookup/index.asp Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 16, 2004 Author Share Posted May 16, 2004 Thanks! So, you're telling me there IS a replaceable filter in my '98 Outback Wagon? Just need to verify due to what I was told by the parts guy at the Subie dealership ("I believe there is no serviceable filter in a '98 Outback")and before I go buy this part and find I can't use it. Thanks. Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 21, 2004 Author Share Posted May 21, 2004 One more (dumb) question... After draining the ATF where do you pour-in new fluid? Certainly not through the dipstick hole, right? Quote Link to comment Share on other sites More sharing options...
99obw Posted May 21, 2004 Share Posted May 21, 2004 I'm afraid that's where it's done. Walmart sells a blue funnel with a long clear plastic flexible hose that works perfectly for both the ATF and front diff lube, though I use a different funnel for each fluid. Quote Link to comment Share on other sites More sharing options...
timn29 Posted May 23, 2004 Author Share Posted May 23, 2004 thanks 99obw! Quote Link to comment Share on other sites More sharing options...
