recommended gear oil?
7 replies to this topic
#1 lvsarge
lvsarge
    Eat, Live, Breath Subaru
  • 256 posts
  • Las Vegas
Posted 30 May 2014 - 01:08 PM
Hi all. Question about gear oil. I'm going to be dropping my transmission on my 79 brat, which is a single range. What is the recommended gear oil for the transmission and rear dif? I put some 75/90 in the transmission to top it off after it had been leaking but I have not done a full drain/fill on it, and I suspect both the trans and rear differential could use it. However, I can't find any factory recommendations as to what specifically goes in each. Any help? Thanks in advance.
#2 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 30 May 2014 - 01:12 PM
Extra S. Its what comes in Subarus right outa the factory. on top of that its amazing to use. Subaru dealerships dont use it on vehicles they service because they have contracts with another company Valvoline or amz? cant remember.
#3 lvsarge
lvsarge
  • 256 posts
  • Las Vegas
Posted 30 May 2014 - 01:39 PM
Thanks for the response.
So,
http://www.amazon.co...d/dp/B007L6Q1EK
This one ^^^ ?
For both Trans and rear dif, yes? And do you know the capacities, by chance?
#4 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 30 May 2014 - 02:15 PM
That's it!
Not sure on the cap though. Rear will prolly be near 1 quart. And I know the eJ 5speeds hold just under a gallon. 3.7quarts if I remember correctly. But not sure about the brat stuff
#5 lvsarge
lvsarge
  • 256 posts
  • Las Vegas
Posted 30 May 2014 - 03:24 PM
So I wonder if this was indeed used/recommended by the Subaru factory in 1979?
#6 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 30 May 2014 - 03:34 PM
This is how we buy it at our shop. Comes right from Subaru in Japan, made by fuji heavy industries. I could almost guarantee that it did.
Edited by Prwa101, 30 May 2014 - 03:35 PM.
#7 Ibreakstuff
Ibreakstuff
    Breaker of stuff
  • 541 posts
  • Carson Valley, NV
Posted 31 May 2014 - 01:58 AM
Most stealerships do not use the good stuff with regular service, but most do have it in the shop if you request it. And some dealerships will even pump it out by the quart for you, I keep a small gas can for extra S only. If any transmission comes in making noises or hard to shift, you can bet that they will try a change with extra S before diagnosing anything.
Edited by Ibreakstuff, 31 May 2014 - 02:02 AM.
#8 lvsarge
lvsarge
  • 256 posts
  • Las Vegas
Posted 02 June 2014 - 10:27 AM
Thanks for the input guys.
