Siamesed EJ/EA adapter?
15 replies to this topic
#1 Uberoo
Uberoo
    Subaru Wheeler
  • 3,719 posts
  • lewiston,ID
Posted 06 June 2014 - 05:21 PM
Of the people that still make adapter plates, who makes the plates with the upper holes siamezed so a single offset bolt goes through the adapter plate to both engine and transmission?I'm looking to remake the steel plate I made along time ago.Tired of having to drill out the holes on the engine.So I'm looking for some of the offset bolts...
#2 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 06 June 2014 - 07:11 PM
Just weld some together bro man, that's all they are.
#3 Uberoo
Uberoo
    Subaru Wheeler
  • 3,719 posts
  • lewiston,ID
Posted 06 June 2014 - 11:52 PM
I thought they were shaved down alittle then welded?
#4 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 07 June 2014 - 06:16 PM
When i did mine i just welded two bolts together and it worked great. Even if they were shaved, you could grind them a little then weld them, just test fit them suckers and you shouldn't have a problem.
#5 Uberoo
Uberoo
    Subaru Wheeler
  • 3,719 posts
  • lewiston,ID
Posted 09 June 2014 - 12:16 AM
yea,I was thinking of sliding the engine and transmission together,and putting some bolts through each one and welding them together where they meet.Then modify the steel adapter plate so they fit.
#6 Uberoo
Uberoo
    Subaru Wheeler
  • 3,719 posts
  • lewiston,ID
Posted 09 June 2014 - 01:26 AM
Does anyone still make an aluminum adapter plate with the top holes milled out?I got to thinking how heavy my steel adapter plate is,and everything could always weigh a little less...
#7 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 3,834 posts
  • Bellingham
Posted 09 June 2014 - 09:51 AM
I can mill out mine if that's what you want, I run smaller diameter studs into the top engine side so no need to drill out threads
#8 Gloyale
Gloyale
    It's a sickness
  • 9,822 posts
  • Corvallis, OR PNW
Posted 09 June 2014 - 11:40 PM
4 or 5 threads in steel is plenty....
in aluminium it's not enough.  That's why the factory threads in the EJ block are nearly an inch deep.
you don't want just a couple threads of aluminum holding your engine and trans toghether.
If I were to run an aluminuim plate, it would be with siamesed bolts.....you're on the right track Uberoo.  I would not trust on;y 1/2" of M8 threads.
#9 4play
4play
    USMB Regular
  • PipPipPip
  • 86 posts
  • southeast idaho
Posted 26 June 2014 - 09:44 PM
I have a guestion about adaptor plates also.the one I saw a pitchure of had 2 ear things on the top of it. what are thay for?
#10 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 26 June 2014 - 09:46 PM
That's for making a pitch stopper my friend!
#11 Crazyeights
Crazyeights
    Crazyeights
  • 1,318 posts
  • Pacific Northwest
Posted 26 June 2014 - 10:17 PM
Scott, your adapter has been working for me like that for years.
Thanks... Jeff
#12 4play
4play
    USMB Regular
  • PipPipPip
  • 86 posts
  • southeast idaho
Posted 27 June 2014 - 09:19 PM
pitch stoper, ok so can some one post a pitcher of the top to bolts, and how thick of a plate do you use for the adaptor .
#13 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 3,834 posts
  • Bellingham
Posted 27 June 2014 - 10:12 PM
Thanks... Jeff
thats a great report thanks
the adapter is the stock bracket from a EA82 trans or 1/8 thick angle Iron would work
#14 Crazyeights
Crazyeights
    Crazyeights
  • 1,318 posts
  • Pacific Northwest
Posted 27 June 2014 - 11:00 PM
The EA81 style pitch stopper bracket works great with Scott's EJ adapter also.
#15 4play
4play
    USMB Regular
  • PipPipPip
  • 86 posts
  • southeast idaho
Posted 28 June 2014 - 01:29 PM
hope you dont think I am highjackung this thred,but I just bolted a pitch stopper bracket from a legacy trans to the dr I have in the garoge. hope to get the adaptor plate cut out ot 1/4" plate this weekend, just need to see a pitchure of the top two bolts, getting closer to having dualrange.
#16 Gloyale
Gloyale
    It's a sickness
  • 9,822 posts
  • Corvallis, OR PNW
Posted 28 June 2014 - 06:28 PM
+1
No need for any tabs on adapter plate.  EJ bracket bolts to EA 5spd.  I suppose with a 4spd maybe woudl be needed.
