to weld or not to weld...
i cant decide if i want to weld the rear diff on my 78 subaru brat. it has a 4 inch lift, and i run 27-29 inch tires on it. i primarily use it off-road, but it does see occasional highway driving and around town. if i weld the rear diff, i know it will help a lot off-road, but im afraid that when i drive in on pavement i will break axles or the diff itself. i know some people weld the diff, then remove an axle for street driving... but that sounds like a pain to do all the time. what are your experiences with welded diffs? should i do it?
Weld it,Over inflate your rear tires for street driving,drive it fast around turns so there is less force on each axle,finally when turning from a stop turn as wide as you can to again minimize the stress on rear axles.I will say though that actually blowing a rear axle or the diff on the street is rare unless you pull the front axles for RWD shenanigans...
However,it is not advised to weld it with a 110 welder,unless you can heat the spiders to a dull red  with a torch to get more penetration.
also when your driving on a slow curvy paved road (sub 35 MPH) it can help if you intentionally drop one of the rear tires into the dirt.
Edited by Uberoo
  • 4 weeks later...
