EA82 rebuild kits?
17 replies to this topic
#1 Tman1058
Tman1058
    Advanced Member
  • PipPipPip
  • 35 posts
  • Potlatch Idaho
Posted 16 June 2014 - 12:43 AM
One of my dad's buddies has an '88 gl wagon for sale that will need rebuilt, he only wants $250 for it so I'm highly considering buying it, but does anyone know where I could get a QUALITY rebuild kit for a REASONABLE price?
And while I'm asking, will factory fuel injection and a set of delta cams work together without problems?
Thank you ahead of time.
-Tom
#2 Dinky26
Dinky26
    ALWAYS LOOKING!
  • Gold Subscribers
  • 720 posts
  • Wichita KS
Posted 16 June 2014 - 12:08 PM
Awesome deal!
How extensive of a rebuild are you looking at?
#3 Tman1058
Tman1058
    Advanced Member
  • PipPipPip
  • 35 posts
  • Potlatch Idaho
Posted 16 June 2014 - 12:48 PM
Hopefully pistons, rods, all bearings and gaskets and probably valve springs. As it sits it runs but I'm told if you pour oil in, it pours right out from an unknown place. And it's got 337k on the clock, so the more new parts the better.
#4 jono
jono
    Reader and writer
  • 1,814 posts
  • Southern Hemisphere - AUS
Posted 16 June 2014 - 05:39 PM
I could only find genuine valve springs for EA82
#5 Dinky26
Dinky26
    ALWAYS LOOKING!
  • Gold Subscribers
  • 720 posts
  • Wichita KS
Posted 16 June 2014 - 06:51 PM
For that kind of money you are looking for all those parts you'd be better off looking for another motor.
When you get into the bottom end of these is when the $$$ start really racking up.
And not to mention the time you would have to input, maybe you have more time than I though.
I know if you're in the Midwest like I'm these cars are not that popular and hard to come by. If you look hard enough you'll find one though. A 2.2 out of a 96 outback or older legacy would be perfect those are rock solid engines.
#6 Tman1058
Tman1058
    Advanced Member
  • PipPipPip
  • 35 posts
  • Potlatch Idaho
Posted 17 June 2014 - 12:48 AM
Anyone know anything about these?http://m.ebay.com/it...7320?nav=SEARCH
#7 mm88swrt
mm88swrt
    oddball
  • PipPipPip
  • 113 posts
  • Rainier, OR
Posted 17 June 2014 - 03:15 AM
Never seen this one. But i would call them to make sure its everything you need. I wouldnt bother replacing rods, they are forged. Pistons are the weak spot. I got a set of wiseco pistons in my ea82t. Its going to be spendy building that little motor that in depth. With parts and machine work to be done. There are some vw springs out there that are stiffer.
#8 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,524 posts
  • Puyallup
Posted 17 June 2014 - 09:49 AM
It's not that expensive to rebuild the engine if you assemble it yourself. $300 for the kit. Pistons, rings, oil pump, bearings, lifters (HLAs)  and gaskets. $60 to turn the crank, $10/hole to bore it ($40). Maybe $200 to have the heads done and of course, you'll want a new water pump, timing belts, tensioner and pulleys. Should be about $700 roughly though it's been a few years since I've done one. If the rest of the car is in good shape, it'd be worth it. If not, like Dinky said, find another one.
#9 AWD J3wman
AWD J3wman
    USMB is life!
  • 176 posts
  • St Louis Park, MN
Posted 18 June 2014 - 03:58 PM
I would look into an EJ18 or EJ22 swap from a 90s era impreza. it might be more economical.
#10 Tman1058
Tman1058
    Advanced Member
  • PipPipPip
  • 35 posts
  • Potlatch Idaho
Posted 18 June 2014 - 04:54 PM
Not trying to b*tch at anyone, but every time i've asked something about rebuilding/improving or other similar topics an ea82, about 1/3 of the response say "ej swap". If I wanted to ej swap that's what I'd be asking about. Now I'm asking if anyone can recommend an ea82 rebuild kit, if you can't provide input on the question, don't say something completely different just to answer.
Hope it didn't come off that I'm pissed, I just get tired of reading "ej swap", when I didn't ask about it.
Thanks
#11 Ibreakstuff
Ibreakstuff
    Breaker of stuff
  • 541 posts
  • Carson Valley, NV
Posted 18 June 2014 - 06:33 PM
Never heard of the brand safety gaskets, not sure how good that kit would be. I would ask where they source the parts for the kit.
I am building several ea82t motors at the moment, all with forged pistons. My recommendation would be to take the motor apart and do an inspection before buying parts or moving ahead with that motor. You will need to know how worn or out of round the cylinders are before ordering pistons. Also depending on how/why the motor needs a rebuild, the crankshaft and rods could have wear/damage from spun/worn bearings. Excessive cylinder wear and damaged crank/rod journals can make even the basic diy sketchy/risky/expensive. That said.. if you have the tools and know how or know a good shop, there is no reason not to go for it. Even if that motor is toast, pick n pull motors can be had with 1 year warranty for cheap (look for 50% day).
As mentioned.. the stock forged rods are usually fine, place them on a flat surface (precision plate) and you can easily tell if they are twisted at all. The concern would be the big end race and how jacked up is it from the old bearing. There are no aftermarket rods that I know of anyways, unless custom (117mm c2c).
Stay EA if you are inclined, shun the non-believers!
Edited by Ibreakstuff, 18 June 2014 - 06:38 PM.
#12 Ibreakstuff
Ibreakstuff
    Breaker of stuff
  • 541 posts
  • Carson Valley, NV
Posted 18 June 2014 - 07:10 PM
ram performance has flat top forged pistons also, I think 9-9.5:1:
http://www.ramengines.com/
#13 skishop69
skishop69
  • 1,524 posts
  • Puyallup
Posted 18 June 2014 - 11:03 PM
The stock EA82 SPFI pistons are 9.5:1. Rods are still available, or were a couple years back when I did my XT GL10 motor. Had to replace the crank and rods thanks to my lead foot driving and old rod bearings. Whoopsie! lol I will always stay EA81, rebuild stock EA82's when necessary, but I would never mod and EA82. They're a great every day motor providing you monitor your cooling system religiously, but there are too many poor design choices to make them stout enough to withstand modding without serious upgrades costing more than lightly modding and EJ and swapping. I am figuring in driving style of having a modded motor based on you built it to pound, and you will. If you don't pound it, it'll survive, but not as long as an EJ.
#14 Xonk61
Xonk61
    Newbie
  • Pip
  • 6 posts
  • Ellijay, GA
Posted 10 August 2016 - 02:45 PM
I'm reading this thread because of a noise my 88 GL started making yesterday, just did a 3 mile test run after replacing head gaskets. I cranked it this afternoon while  friend was listening, and he says it's a rod, rebuild/replace engine.  I may be misunderstanding what I read here, rods are usually pretty substantial, and may not be the problem?
background, the car was driven for a few miles with blown head gaskets, water in the oil.  Probably been up to temperature for a couple of miles in that condition.
I guess I'm hoping for a suggestion that isn't as extensive (expensive) as replacing or rebuilding the engine before I tear back into it again.
#15 DaveT
DaveT
    Subaru Nut
  • 3,719 posts
  • Colchester
Posted 10 August 2016 - 04:28 PM
Is it a deeper clunky sound, or a thin ticking sound? TOD?
I once ran one with 50 / 50 oil and water in the crankcase. A few times, at 65 on the highway. Before I discovered the water had been dissappearing into the crankcase. .. Ooops! I was running expensive 100% synthetic oil. Had no problems with the bearings after I replaced the headgaskets, which had been blown by the overheat while low on coolant problem that caused the mixing. It did burn oil like crazy however.
#16 golucky66
golucky66
    Subaru Nut
  • 585 posts
  • Barkhamsted Connecticut
Posted 10 August 2016 - 05:31 PM
Rockauto has upper and lower gasket set. Crank bearings. Valve springs. Bunch of stuff.
I'm really surprised no one mentioned it. No pistons though.
#17 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 10 August 2016 - 08:02 PM
Sorry for hijack the thread, but I should ask, about this:
Where?
I need a set of Hydraulic Lifters and Springs for an EA82.
Kind Regards.
#18 Xonk61
Xonk61
    Newbie
  • Pip
  • 6 posts
  • Ellijay, GA
Posted 11 August 2016 - 08:14 AM
DaveT, after reassembling the engine, there was a thin ticking noise, and it made that noise for a few miles. The next morning though, when I cranked it, it started making the knocking noise.
