Will Outback 16" wheels fit Legacy?
7 replies to this topic
#1 Brat78
Brat78
    USMB Regular
  • 131 posts
  • Richmond Hill, GA
Posted 18 June 2014 - 05:16 AM
Just wondering if I can put a set of factory Outback 16" wheels on my 94 legacy without them rubbing. I know the pattern and offset are the same, just wondering if they will physically fit. Thanks in advance for the help.
-Skip
#2 987687
987687
    Rally Suby!
  • 4,264 posts
  • Northern Maine
Posted 18 June 2014 - 05:48 AM
The wheels will fit fine, the outback tires might be too big. 205/55/16 is the usual tire size legacys have with 16" rims, and that size would work well.
#3 heartless
heartless
    Do YOU Subaru?
  • 3,340 posts
  • North Central Wisconsin
Posted 18 June 2014 - 06:35 AM
With stock Legacy struts you will be limited in what you can fit without them rubbing on the spring perch
With Outback or Forester struts you can go larger much more easily
use this to help you determine sizing...
http://www.miata.net...e/tirecalc.html
#4 TheYeti
TheYeti
    Carp in Denim!
  • 505 posts
  • Arvada
Posted 18 June 2014 - 08:56 AM
I think 195/55 range would work.  A 205/50 might fit as well.
#5 TheLoyale
TheLoyale
    Safariwagon: The Legend
  • 7,079 posts
  • Waukesha, WI
Posted 18 June 2014 - 10:19 AM
Anything smaller than 225/60/16 will fit using the stock Legacy struts. Outback Struts have a higher spring perch.
#6 Brat78
Brat78
    USMB Regular
  • 131 posts
  • Richmond Hill, GA
Posted 18 June 2014 - 05:40 PM
Are the outback/forester struts bolt on for gen 1 legacy? I do appreciate all the responses.
Edited by Brat78, 18 June 2014 - 05:40 PM.
#7 bratman18
bratman18
    ADIDASubarus
  • 3,866 posts
  • Jefferson, Maine
Posted 18 June 2014 - 05:52 PM
you need to put your rear top hats on the rear struts. Other than that, they bolt on. But if you just want to run the outback wheels, they will fit just fine with a smaller size tire.
#8 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 18 June 2014 - 10:34 PM
If you did want to lift your Legacy and have a nice tight feeling with less body roll, '96-'99 Outback struts with '98-01 Forester springs are the way to go. My '95 handled like a track car with this setup and Potenzas (Granted I used all new components)
Food for thought.
