WASHroad Posted June 19, 2014 Share Posted June 19, 2014 Hi all, I had just picked a 91' Wagon, put new head gaskets on it.. Went for a few test drives around the block, like 2- 4 miles and ran great. not my drver so I haven't been driving it however I thougth I would drive it into work today which is like a 11 mile drive. Car just sputtered and died as I was getting into the parking lot. It started back up but with no idle, then died. Did that a few times to get in a parking spot and am sitting here hoping it will run to get me back home. Felt like maybe a fuel issue, but looking for other ideas.. the car has 137K and the gasket swap went well. thanks Quote Link to comment Share on other sites More sharing options...
WASHroad Posted June 19, 2014 Author Share Posted June 19, 2014 Tried to drive home. Started right up. Ran great for a few miles like unt full operating temp. Then same thing feels like running out I gas. But why would the fuel pump quit with engine temp? Or is there a common señor that fails once warmed up. Quote Link to comment Share on other sites More sharing options...
stratman977 Posted June 19, 2014 Share Posted June 19, 2014 (edited) Clogged air filter? Mine got swamped in a terrential downpour and had the same symptoms. Took the soaked filter out and it fired right up. Edited June 19, 2014 by stratman977 Quote Link to comment Share on other sites More sharing options...
Subruise Posted June 19, 2014 Share Posted June 19, 2014 are all of the intake boots tight? did you unplug the TPS or MAF sensor during your HG job? are they secure? this happened to me and it was a plug wiggling around and loosing connection, gotta put those metal clips back in there Quote Link to comment Share on other sites More sharing options...
Dee2 Posted June 20, 2014 Share Posted June 20, 2014 If it feels like fuel issue to you then it probably is a fuel issue. Your description does sound like it is a fuel pump problem. Quote Link to comment Share on other sites More sharing options...
WASHroad Posted June 20, 2014 Author Share Posted June 20, 2014 Got the car home. Each time I went to drive it it ran for less time. Ended up towing it the last 3 miles. Durin the last run period the engine wasn't running as well the tack was jumping around in the last minute or so of run time. Seems what ever the problem is it is getting worst. Will think about it a few days since the weekend is busy with grads and things. Thanks for the input. Quote Link to comment Share on other sites More sharing options...
