80 gl conv rwd?
rwd
68 replies to this topic
#51 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
  • Granite Falls, Washington
Posted 29 June 2014 - 07:57 PM
Nick are you in the pnw? If so you should come out and help with the "little" project.
#52 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
Posted 29 June 2014 - 08:12 PM
Don't just cut the axle. Remove the whole cage assembly from the cup. Just leave the cup and attached axle piece through the hub. I always keep a couple of these laying around, just in case. I do warn you again that you will be putting lots of extra strain on the diff. I exploded a welded diff with 26" tires.
Also these.
#53 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
Posted 29 June 2014 - 08:13 PM
Also these.
I can't open any of the links.
How does one go about taking out the cage assembly?
#54 nick1208
nick1208
    New User
  • 330 posts
  • Tacoma WA
Posted 29 June 2014 - 08:32 PM
yes I am. PM me
#55 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 29 June 2014 - 10:17 PM
 I Think you mean transfer gear.....not the ring gear in the front diff correct???
I welded my transfer gear collar rigth to the gear to keep maximum engagement on the teeth in my T-cased rig.......no need to use the FWD option.
But that is T-cased not really relavent here.
Oops, without actually tearing into the trans I'm sure you're correct
#56 Vegablade
Vegablade
    Eat, Live, Breath Subaru
  • 548 posts
  • Concrete WA
Posted 30 June 2014 - 09:36 AM
This is what happened to his car.  He emailed me this.
I explained to him how it would be far easier in the long run to just fix it right and be done with it.  RWD is fun, but only if its done right.
#57 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 30 June 2014 - 10:20 AM
That look overextended to me.  Aftermarket tripod joint for sure....but I don't see anything "broken"
Does that car have an "over stock" lift??
#58 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
Posted 30 June 2014 - 11:28 AM
I believe that it is stock but I am not sure.
#59 TOONGA
TOONGA
    I divided by zero
  • 193 posts
  • Australind
Posted 04 July 2014 - 04:37 AM
I'm probably going to do this. So do i need stubs or can i just remove the front axles that attach to the knuckle?
You need the outer CV joints so that the wheels roll and your steering works.
TOONGA
#60 sumoco
sumoco
    USMB is life!
  • 235 posts
  • Portland, Oregon
Posted 10 July 2014 - 08:10 PM
So I just bought a 80 hatchback that was converted into a rwd drift machine. The dude before me had taken the innards from a single range loyal tranny and put them into an ej22 bell housing, chopped and welded the front axle nubs and lowered it so it sits about 5 inches off the ground. It's about to have my ej22 dropped in and we shall see how well it actually handles
#61 nick1208
nick1208
    New User
  • 330 posts
  • Tacoma WA
Posted 10 July 2014 - 09:42 PM
Is this the red one on white wheels? Pics?
#62 sumoco
sumoco
    USMB is life!
  • 235 posts
  • Portland, Oregon
Posted 10 July 2014 - 10:41 PM
Nope it's a white one from Yakima Washington, it's covered in stickers( in the process of removing them) and has the rear windows tinted
#63 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
Posted 18 July 2014 - 12:54 PM
I fixed the чертовскй cv axle and it broke after half a mile. I think my car was destined to be rwd.
#64 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 19 July 2014 - 10:00 AM
You did something wrong.
Miss one of the rings on that Tripod?
Should....Get rid of the stupid aftermarket crap tripod axle anyhow.
Do it right with a good axle and it should not break.
#65 19804wdPOS
19804wdPOS
    Advanced Member
  • PipPipPip
  • 32 posts
Posted 19 July 2014 - 03:45 PM
I put a new oem cv axle in. I followed every step. It happened again.
#66 sumoco
sumoco
    USMB is life!
  • 235 posts
  • Portland, Oregon
Posted 19 July 2014 - 06:07 PM
RWD!!!!!!!!!!!!
#67 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 19 July 2014 - 07:08 PM
what about this rwd EJhatch?
#68 sumoco
sumoco
    USMB is life!
  • 235 posts
  • Portland, Oregon
Posted 19 July 2014 - 07:38 PM
Still trying to find time to slam my ej22 into it, been slammed with work. Going to try to bring it up to wcss
#69 rallybeast22
rallybeast22
    Newbie
  • Pip
  • 7 posts
  • Courtenay, B.C
Posted 03 June 2015 - 01:01 AM
How do you weld the transfer gear collar to the gear? I have to replace my rwd s/r gear box every year or soo.
Also tagged with one or more of these keywords: rwd
