1986 brat swap
brat swap ea81 ej20 ej22 ej20t ej22t
1 reply to this topic
#1 plawrence77
plawrence77
    Newbie
  • Pip
  • 1 posts
  • United States
Posted 25 June 2014 - 02:16 PM
so I'm just trying to see if this is possible. what i'm thinking about doing to taking a 86 brat and pull the motor and trany. i've found a donor car that i would take the trany, drive line, rear diff, and cv axles out of so i would have stronger parts to hold up better. i figured i would have to get a drive line made to fit the right length. i want to put a ej20 or ej22 motor into it to give it some go. the donor car is a mid 90's legacy. i just want to try and find out what i need to do before i get to deep into this build and get stuck. anything will help out.
#2 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,507 posts
  • Puyallup
Posted 26 June 2014 - 09:27 AM
From what I remember on reading for a swap of this nature...
The ECU, engine harness cut down and excess removed, build a cross member for the tranny. hybrid axles as neither the Brat or the Lego axles will work, custom shift linkage and driveline. I believe the rear diff may be a bolt in, but don't remember for sure.
Also tagged with one or more of these keywords: brat, swap, ea81, ej20, ej22, ej20t, ej22t
