good tires for stock motor?
lift tire size stock motor
17 replies to this topic
#1 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
  • Englewood Colorado
Posted 30 June 2014 - 09:00 AM
So Ive been taking my '82 brat off road finally  :D, the one thing i really enjoy is how well this little guy can actually climb! I'm ready to do my lift but I guess I wanna pick a tire size first. the tire ive been looking at is the general grabber 27x8.5x14. my question is how well can the stock motor push this tire? I'd hate to lose my low range advantage over the legacy in my group ;P
Side note: after browsing literally hundreds of photos of lift/tire size, can this tire fit with a 2" lift and some trimming. not all 2" lifts look the same, im ordering from SJR. I'm leaning more towards a 2" lift in the front over a 4"/2" to keep the center of gravity lower,(+ less work/cost).
-Cheers!
Edited by m12-lrv, 30 June 2014 - 09:02 AM.
#2 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 30 June 2014 - 09:10 AM
Also, I am rockin the 5 spd trans, Ive heard that they have a deeper low range.
#3 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 30 June 2014 - 09:27 AM
read more. Because if you had you would see that those motors are pushing WAY bigger tire than you are contemplating.
NOT cheers...
Edited by monstaru, 30 June 2014 - 09:27 AM.
#4 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 30 June 2014 - 03:23 PM
trust me i have done A LOT of reading, but i have not seen mention of stock motors and performance. MCbrats monster runs an EA-81 with 33" tires, but he is also running a trans-case after a low range gearbox. Also, im way over a mile above sea level in elevation while off roading. not much air to breath, my car at sea level would feel like it was supercharged. and to be fair, most of the lift/tire threads do not mention motor size.
A simple "yes you should have no issues climbing a 45+ degree slope" will suffice.
-CHEERS
#5 subiwag
subiwag
    New User
  • PipPipPip
  • 56 posts
  • Northgate, WA
Posted 30 June 2014 - 04:15 PM
Sjr does not offer a 2" lift for your brat
#6 spazomatic
spazomatic
    USMB is life!
  • 461 posts
  • castle rock
Posted 30 June 2014 - 04:22 PM
Another colorado boy! Im a bit south of castle rock...
When it comes to ea81, tire size and driveability, its all relative i guess. You could throw 35s on there and run it offroad, but would you personally be able to deal with that on the highway? not me. Im runnin 215x75-14s (26" with no lift) and my ol' 84 is a bit of a pig out on the highway. But hey, it was with stock tires too!
Off road mine does ok...theres only been a couple times atop a gnarly climb where i was like, "aw shoot, she isnt gonna make it and ima hafta back down this mess"...but it always made it. Amazing how slow that little motor will spin.
Im still in the middle of swappin in my 5spd, so i cant opine as to whether the low range in it will make a lot of difference over the 4spds.
But I'll say go for it and get the 27s. Better that, than wishing you had gone bigger.
Gesundheit
Edited by spazomatic, 30 June 2014 - 04:25 PM.
#7 bratman18
bratman18
    ADIDASubarus
  • 3,866 posts
  • Jefferson, Maine
Posted 30 June 2014 - 04:35 PM
I ran tires that were just under 27" on my brat that was lifted 2". It worked well. Still had a decent amount of power. I recommend Highguyslifts.com for a lift. They are built stronger, and he is great to deal with.
#8 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 30 June 2014 - 08:31 PM
I have so much to say it's almost criminal not to say it.
cheers that bitch
#9 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 30 June 2014 - 09:10 PM
Back to the original posting, Ive emailed scott and it is available "$250 , you should do it, it will level out the car".
Edited by m12-lrv, 30 June 2014 - 11:29 PM.
#10 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 01 July 2014 - 01:42 PM
-CHEERS
Not without fuel injection you wont.You will loose some gearing,its just the nature of the beast.1st lo idle will go from 2 MPH to like 5 MPH,but the bigger tires will have enough grip otherwise to make up for the difference.
#11 Vegablade
Vegablade
    Eat, Live, Breath Subaru
  • 548 posts
  • Concrete WA
Posted 01 July 2014 - 06:02 PM
It depends on how much offset your wheels have.  I have 27x8.5x14 bighorns on my 4" lifted BRAT with lots of negative offset and they rub in the front when turning.  As for power you will notice a loss and your gearing will no longer be as low as it was with stock tires.  I also ran these on my GL for quite a while with a 2" and could cruise pretty easily on the highway but had to downshift into 4th to pull large hills.
#12 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 02 July 2014 - 12:06 AM
Yep,with the lift and bigger tires,offroad= 1ST lo or maybe 2nd Lo on some faster sections.
#13 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 06 July 2014 - 05:12 PM
For $250 you could buy a chop saw,blade , steel , and bolts. Just saying.
#14 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 12 July 2014 - 01:29 PM
OP what is your level of mechanical aptitude?
#15 Hsoj
Hsoj
    Advanced Member
  • PipPipPip
  • 119 posts
  • seattle wa
Posted 14 July 2014 - 10:06 AM
I have a 2" lift on my ea81 and I would not do it again. It suffices but its a pain to get in. Just go for a 3". It gives you room for a wrench and itll be easier to find a way to connect the steering using stock parts.
#16 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 14 July 2014 - 09:22 PM
I have thought about making it myself but I don't trust myself getting the measurements spot on for the camber. Someone else with a jig, who does it for a living, will get it right the first time. After doing some measuring, 27's really are not a lot bigger in radius but the tire will be wider. I'd love to go with a bigger lift but I'm trying to stay sensible. My BRAT already gets to a lot of places I wouldn't expect, I'm just looking for a little more clearance. with the tire/combo the body should sit about 4.5 inches higher than stock.
#17 AKghandi
AKghandi
    Alaskan Subaru nut
  • 1,205 posts
  • Anchorage Alaska
Posted 12 August 2014 - 02:07 PM
I put 29x8s on my 2" lifted wagon, i have a carbed ea82 and i also have the 5 spd dual range.
It will do the highway, but just barely. our speed limit is 65.
I wish i had either smaller tires or more power as it runs out of grunt pretty quick off road
Edited by AKghandi, 12 August 2014 - 02:09 PM.
#18 spazomatic
spazomatic
    USMB is life!
  • 461 posts
  • castle rock
Posted 12 August 2014 - 08:59 PM
Oops, i lied. I reread my previous post...im running 205x75-14s, not 215x75-14. Doesnt matter. My bad. Carry on.
Also tagged with one or more of these keywords: lift, tire size, stock motor
