A ton of shifter slop. '95 Legacy 5spd.
12 replies to this topic
#1 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 05 July 2014 - 03:26 AM
So i picked up this wagon and the 5spd has a rediculous amount of slop in it. Today i pulled the shifter boot expecting to see a couple mangled shifter bushings, only to find everything in real good condition.
Is the slop going to be internal or is there something else I can check?
Thanks
-Brian
#2 lvsarge
lvsarge
    Eat, Live, Breath Subaru
  • 256 posts
  • Las Vegas
Posted 05 July 2014 - 04:09 AM
I don't own a legacy, but on my 06 impreza a lion's share of the slop was remedied when i changed the front and rear shifter linkage bushings to poly under the car -- you wouldn't be able to see them from the top, I do not think.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,966 posts
  • Charlottesburg, VA
Posted 05 July 2014 - 11:05 AM
The slop comes from the u-joint kinda thing on the transmission end of the linkage. Scoobymods used to have a thread with a write-up on replacing the joint on newer Impreza.
The legacy joint is similar but on the older ones it has bolts instead of rivets so you could replace just the bushings for about $3 each.
#4 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,046 posts
  • Honolulu HI
Posted 05 July 2014 - 02:47 PM
What Fairtax said--it's definitely the bushings in the "boss joint" (the u-joint thingy) that connects the shifter rod to the tranny input.
Been a lot of discussion of the job over the years.  Try a "search"--go to advanced search, enter shifter bushings and choose New Gen Forum.
Here's something I wrote up in '07:
http://www.ultimates...ifter +bushings
Good luck!
#5 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 06 July 2014 - 01:59 AM
Thanks everybody.
I did a search and the only real guide I found was yours Olnick.   In yours, you mention to Subyluvr his guide, but I could not find his.
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 10 July 2014 - 12:06 PM
I still cant find any guide written by Subyluvr.
#7 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,046 posts
  • Honolulu HI
Posted 11 July 2014 - 12:22 PM
Finally tracked down some info!  It's all bits-and-pieces from years ago but I hope it helps you.
Back when I did mine, one of my best resources was the exploded view drawing in the Haynes Manual, page 7A-2.
Here's "subylovr's" write-up (he changed his user name to "DerFahrer")--but pictures are gone:
http://www.ultimates...ngs#entry493970
Another write-up (but the photos don't seem to be accessible):
http://www.ultimates...ge-photos-here/
Here are some good pix of the parts from Nasioc:
http://forums.nasioc...ad.php?t=742063
Ask any questions you have . . . maybe more specifics will come back to me!  And good luck--it's really worth the effort if you can bear with the pain!
#8 gdudik
gdudik
    New User
  • PipPip
  • 24 posts
  • Vancouver, WA
Posted 11 July 2014 - 05:46 PM
Slightly OT, but I'm going to ask a small favor. In Jan 2013, on my wedding night, I had a 95 Legacy wagon stolen from the hotel room parking lot. It also had a 5 speed with a lot of slop in it. The vehicle was never recovered.
I know it's very unlikely that it's the same car, but I'm from the Portland, OR area, and I was wondering if it might have made it down to where you are. If you just purchased it, did you do any kind of carfax or something like that to see if the VIN came up stolen?
Mine was dark red. I proposed to my wife on the beach in that car. I still hold out faint hope it will come back.
Thank you!
--Graham
#9 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 11 July 2014 - 11:53 PM
Thanks a million!!  That nasioc thread is exactly what I needed.   Ive been reading that there are several different changes made to this part across model years, so I am hoping a guide like this will help me track down the correct parts.
I forgot SubyLuvr changed his name...  that explains why nothing came up.
gdudik, i did not run a carfax or anything, but my car is white, has no ABS and rear drum brakes but power windows... and a salvage title.   Don't think its going to end up being your stolen sube.   Sorry to hear about your misfortune.
#10 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,046 posts
  • Honolulu HI
Posted 12 July 2014 - 12:41 AM
You're welcome.  I was tickled I could find all that stuff again too!
One bright spot--my car is also a '95 Legacy and it has the simplest boss joint.  It's held together with nuts & bolts, so access to the bushings is pretty simple.
Again, good luck!  Keep us informed on your progress.
#11 gdudik
gdudik
    New User
  • PipPip
  • 24 posts
  • Vancouver, WA
Posted 17 July 2014 - 02:09 PM
Yup not mine. I just liked that car! Thanks anyway.
#12 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 19 July 2014 - 03:21 PM
So I was speaking to a friend of mine who has done this before, and he said on his trans he just removed the bolt holding the u-Joint to the transmission side...  instead of removing the double spring pin & "Y" piece.   I might try this method as it sounds a lot easier than removing 2 roll pins.
I also found this replacement joint:  http://turninconcept...age-update.html
its a little out of my budget at the moment, and im not even sure it will work.  Im sure i have a centering spring on mine, i will know more when I get under the car and take it out.   Im sure all I need are new bushings, and don't feel like emptying my wallet... besides, im still not sure exactly which bushings will work in my '95, i have not found any definitive information on the differences between models and years.   But im going to continue searching.
#13 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,046 posts
  • Honolulu HI
Posted 19 July 2014 - 04:55 PM
That's exciting that TurnInConcepts has bushings for the "boss joint."  They didn't offer them back when I did mine.  And no one has ever been happy with the longevity of the Subaru OEM bushings!
No idea why their boss joint unit is only for "springless" models. You might try contacting them and asking.  I dealt with Clint, one of the owners of TiC and a Subaru guy himself--really nice guy.
If they sell just the bushings I think it'd be a good investment.
As for removing just the bolt holding the joint--good luck!  As I remember there's no way to get a wrench up in there.  I wish you success and if you accomplish it, by all means let us know how!
Good luck!
