simple question
So I got a simple easy question...how many fuses should be hot all the time on a 88 gl-10 ? I think it should only be two our three right? Radio, clock, and door locks...I hope somebody knows...I have been fighting a draw issue and last night I pulled fuses to prevent the draw and I pulled a little over 10 total...anyway thanks!
As you pull the fuses, check your multimeter to see if there was a drop in draw from that circuit.   That would be where your battery drain is coming from.
  I'm not sure how many should be hot w/o ignition.    I could test my 85 ea82 tonight.
