Air suspension trouble on Leone
Suspension pressure sensor compressor
1 reply to this topic
#1 TomasBacklund
TomasBacklund
    Newbie
  • Pip
  • 1 posts
  • Pietarsaari
Posted 17 July 2014 - 12:34 AM
Hello!
I have a 1988 Leone 1800 turbo with air suspension. Something lead to that the compressor was running all the time and broke down (probably faulty damper). I have now changed the compressor (and some faulty rear dampers) and the system fills up and stays filled up like it should. I havent managed to figure out why the compressor doesn't stop when the system (dampers and airtank) are filled up. I tried to change the pressure sensor on the tank but that didn't work. How can I tell if the sensor is broken? I can't get any readings on my multimeter! Anyone with good ideas? I do have the wiring diagram.
Tomas
#2 john in KY
john in KY
    1000+ Super USER!
  • 1,672 posts
  • KY
Posted 17 July 2014 - 02:48 AM
Just a guess but sounds like there is an air leak somewhere in the lines. I'd check all the airline connections with soapy water looking for bubbles. My understanding of the system is the compressor charges  the air tank and the tank air charges the dampers. On North American models, the relay for the compressor is located behind the left front strut, close to the firewall and next to the brake MC. It is protected by a rubber boot. You can remove it to stop the compressor from running.
Also tagged with one or more of these keywords: Suspension, pressure, sensor, compressor
