How do I count front differential teeth on 4EAT?
10 replies to this topic
#1 Corvid
Corvid
    New User
  • PipPipPip
  • 89 posts
  • Puget Sound
Posted 21 July 2014 - 07:38 PM
I have a feeling there is something obvious that im missing here, but this has been a long project and I need to eat something, so I'm getting frustrated.
I've got the transmission hanging from an engine hoist. It's a JDM 1997 4EAT that is off a 2.5l car, but is supposed to have a 4.11 ratio. I want to check the front diff visually before I commit to installing it.
I pulled the drain plug, and marked the tooth in front of me with a sharpie. What is the detailed, correct technique for getting that gear to turn so I can count teeth? I've tried a couple things that made sense to me, but nothing that has made the gear seem to move.
I'm gonna go get food, thanks for reading.
#2 Crazyeights
Crazyeights
    Crazyeights
  • 1,463 posts
  • Pacific Northwest
Posted 21 July 2014 - 07:54 PM
I would try and hold one of the front output shafts and then turn the other one. I would think this should cause the ring gear to rotate.
Edited by Crazyeights, 21 July 2014 - 07:55 PM.
#3 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 21 July 2014 - 08:12 PM
or just plug the number into these here webs and find out. Edrach(RIP) found a nice long list of transmissions that is pretty complete. I am sure if you searched a skosch you would find it. Then you would just know.
#4 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,107 posts
  • East Coast
Posted 21 July 2014 - 08:47 PM
+1
is the transmission part number on the case?
#5 presslab
presslab
    Subaru Nut
  • 868 posts
  • N. California
Posted 21 July 2014 - 09:08 PM
You should be able to read the stamping on the ring gear through the drain plug hole. You'll need to rotate it into position. Make sure it's not in park and do as mentioned above, hold one stub shaft and turn the other.
Edited by presslab, 21 July 2014 - 09:10 PM.
#6 Corvid
Corvid
    New User
  • PipPipPip
  • 89 posts
  • Puget Sound
Posted 21 July 2014 - 09:58 PM
Ok, thanks you guys, got it moving.
I tried what crazyeights, gary, and presslab said (thank you for elaborating), but it was still binding.
Not wanting to force it, I wondered about the mechanical speedo sender that I plugged in from the 91 transmission...
Pulled it out, and now I've got a rotating gear, that reads...49?
I thought I was looking for more like 37. I gotta find that chart on here somewhere, and actually count these teeth one at a time.
#7 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 22 July 2014 - 08:44 AM
yes, the 4.11 ratio will have 37 teeth on the ring gear.
the 4.44 will have 40 teeth.
#8 Corvid
Corvid
    New User
  • PipPipPip
  • 89 posts
  • Puget Sound
Posted 22 July 2014 - 03:49 PM
Alright, 37 teeth counted and triple checked. I have no idea why it is scribed "49" on the back of the ring gear itself.
Now I just gotta go figure out whats going on with this VSS.
Edited by Corvid, 22 July 2014 - 03:49 PM.
#9 presslab
presslab
    Subaru Nut
  • 868 posts
  • N. California
Posted 22 July 2014 - 06:01 PM
Where was it scribed at? Normally it's stamped on the outer edge, like "S 37:9 xx xxx". The "49" probably has something to do with the pinion depth.
#10 Corvid
Corvid
    New User
  • PipPipPip
  • 89 posts
  • Puget Sound
Posted 22 July 2014 - 09:06 PM
Hmm. I didn't see any stamped numbers, the 49 looked electro-penned on.
It was about the size of a thumbnail, maybe a little bigger, at the base of one of the teeth.
Edited by Corvid, 22 July 2014 - 09:07 PM.
#11 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 23 July 2014 - 05:35 PM
remind me again just what the problem is????
