I need help with my A/C
Hi, so my carb on my 1984 subaru gl is junk and sometimes it idles high and sometimes it idles slow. Anyway when running the A/C and coming to a stop it will kill the engine so I would turn A/C off then back in when I start moving again. Well the other day I turned it off and it wouldn't come back on... There are no fuses blown, I hooked 12v battery directly to the blower and it ran, I figured it could only be the A/C relay so I replaced it and still the A/C won't come on... Can someone give me some advise on how to fix this? Thank you
Can anyone give me some advice on what other relays or fuses I need to check? Recap: no fuses are blown, the a/c blower works when connected straight to a 12 battery, replaced the relay under the hood... Thanks
Did you check the main switch ?
I have checked and rechecked fuses, I have taken the relays apart and checked them, the only thing I can think of is that the main switch has went out. Can someone give me some advise on the easyest way to get those switches out? Will I need to take the whole dash out? Is there anything else I should look for? Thanks
Problem solved! There are fuses n the fuse box and there are relays under the hood AND there is a round glass fuse under the steering wheel bottom cover, I found it by accident. I had tried everything I could possibly think of and had already said F it, winter is coming. So I was stuffing the wires up so I could put the cover back on when the A/C came on! So I crawled under there and dug until I found it and it wasn't blown it was just not making a good connection, I twisted it and it works fine now. Makes me wonder what else has hidden fuses?!?
