BFN Posted May 11, 2004 Share Posted May 11, 2004 Hello I tried looking this up with the search function, but didn't quite find what I was looking for. So maybe some of you could help. I have an 86 EA82 N/A MPFI 3 door coupe, which resently started leaking fuel. I'm going to replace the fuel tank, but I wonder if there are any differences in the tank regarding MPFI, SPFI, carb? Do I need a special MPFI tank? I've assumed all EA82's have the same tank. Also my idiot lights are shining bright and clear, except for the oil and ECM. I've learned this is usually caused by the diodes in the alt going bad. Are there any other posibilities? Thanks for all help on this, and previous matters BFN Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 11, 2004 Share Posted May 11, 2004 I believe you are right on the fuel tank and the alternator diagnosis. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted May 12, 2004 Share Posted May 12, 2004 The lights comming is sometimes a loose ground wire for the instrument cluster. Check that firs before dropping the money on and Alt Quote Link to comment Share on other sites More sharing options...
