EJ22 / 2.2 SINGLE port exhaust gasket part number and HLA Bleed
11 replies to this topic
#1 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 26 July 2014 - 04:53 PM
Swapping a '96 2.2 into a '98 Forester.
Edit: I was thinking I was looking for a 3 bolt-hole gasket- doesn't exist for the SINGLE-PORT heads.
#1: Having trouble finding the SINGLE port exhaust gasket that goes between the y-pipe exhaust manifold and cylinder head. It's NOT the DUAL port.44022AA020>>> 44011AC030.
EDIT found: Subaru part number should be: 44011AC020
EDIT - found: This should be correct (and 1/2 the price of dealer): MS 97055 Felpro.
This gasket was used on the '96-'98 EJ22  used in the Impreza, Legacy.
Not found @ Autozone, NAPA, NOR THE LOCAL SUBIE Dealer. They ONLY showed the DUAL port for all years. WTH?
#2: Also, the 2.2 has sat @ the local yard - in their shop - for @ last 3+ years ( I almost bought it 3 years ago for another project). Should I BLEED the HLAs before installing the engine?
Thanks,
Td
Edited by wtdash, 27 July 2014 - 08:10 PM.
#2 86BRATMAN
86BRATMAN
    Elite Master of the Subaru
  • 3,964 posts
  • Tazewell Virginia
Posted 26 July 2014 - 05:52 PM
Do you have an advance auto nearby? They had no problem getting me a set of single port gaskets a few months ago, the one in my town had them in stock. Felpro brand, if I was at home I could probably get you the part number.
I didn't bleed the hlas on my forester swap, it was noisy for a little on start-up. It went back to normal hla quiet pretty quickly. It had also sat for multiple years before I swapped it.
Edited by 86BRATMAN, 26 July 2014 - 05:53 PM.
#3 ocei77
ocei77
    Eat, Live, Breath Subaru
  • 872 posts
  • Monticello,NY
Posted 26 July 2014 - 10:07 PM
A search of Advance show they sell the Fel-Pro set for 10.99.
Fel-Pro no MS 97055
O.
#4 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 26 July 2014 - 11:19 PM
^Thanks, but as noted EDIT: I don't 'think' that's the right part.10030247_fel_ms97055_pri_mini.jpg
Edited by wtdash, 26 July 2014 - 11:30 PM.
#5 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 26 July 2014 - 11:21 PM
Nothing close...must be an east coaster? I tried to search on RockAuto, etc. too...must not be avl. west of the Mississippi! :-(
See below...were your gaskets 2 or 3 bolts holes?
Thanks
Edited by wtdash, 26 July 2014 - 11:33 PM.
#6 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 26 July 2014 - 11:32 PM
Hmmm, I'm now wondering if the 'new style' is just the 2 bolt hole.....I was thinking it should be 3 bolt holes, since there are 3 studs to hold it on?
P/N: 44011AC020 might be correct...which is probably the MS 97055.
#7 86BRATMAN
86BRATMAN
  • 3,964 posts
  • Tazewell Virginia
Posted 26 July 2014 - 11:50 PM
Mine only has 2 bolts. Pretty sure all the single ports are that way. I can see how the other large hole in the flange would make one think there could be 3 bolts. But that gasket looks identical to what I put back on my legacy.
#8 ocei77
ocei77
  • 872 posts
  • Monticello,NY
Posted 27 July 2014 - 07:04 AM
there were places for three bolts, but there should only be two actual studs. The listed part is correct.
O.
#9 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 27 July 2014 - 10:05 AM
If you have 3 studs its a dual port engine.
Only 2 studs on single port.
I've bought single port gaskets at the dealer and Advance auto, and Napa before, but it does sometimes take some looking through the listings to find them.
#10 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 27 July 2014 - 08:07 PM
Thanks guys..that seems to be the issue - expecting a 3 bolt-hole gasket - which doesn't exist.
#11 subykyleej22
subykyleej22
    Newbie
  • Pip
  • 2 posts
  • United States
Posted 07 October 2014 - 07:03 AM
hey guys i also have a ej22 with single port exhaust and was wondering if any of you would know where i could find the part number for those cylinder heads. i cant seem to find them / it anywhere.
I picked up a 98 legacy with a 96 ej22 with bent valves for dirt cheep and i am looking to hunt down some good remanufactured and or new cylinder heads depending on the cost.
What do you think would be my best value ?
#12 wtdash
wtdash
    Subaru Nut
  • 1,593 posts
  • N. ID
Posted 07 October 2014 - 09:42 AM
HI,
1st off, a '96 was the last year of NON-interference EJ22's. Have you pulled it apart to verify?
New heads are more than the car's worth. Here's a LINK to opposed forces that shows part numbers.
EDIT: They're about $300/side.
Find another set of heads from an EJ22 - any year from '90 to '98. If yours has EGR look for my post on using a NON-EGR head.
TD
Edited by wtdash, 07 October 2014 - 09:45 AM.
