BestCar/OnlyCar Posted July 27, 2014 Share Posted July 27, 2014 (edited) Hi,I just put two new CV joints into my 1988 GL. Now it is making loud clunking type noises. (not when I turn, just occasionally when driving) My question is this: I put new seals on the inside. When I put them on I just used the new CV axles to pull them into place. It seemed to me they did not go in as far as the old ones did (which were snug against the wheel bearings). If I did not get my seals in far enough would that cause a noise or? Anyone know anything about this? They were a pain to change and it is so lame now that it is not all wonderful...Thanks, Patty Edited July 27, 2014 by BestCar/OnlyCar Quote Link to comment Share on other sites More sharing options...
BirdMobile Posted July 27, 2014 Share Posted July 27, 2014 How tight did you torque your castle nut? Quote Link to comment Share on other sites More sharing options...
BirdMobile Posted July 27, 2014 Share Posted July 27, 2014 One other thing... Did you remember to re-install the roll pins where the DOJ meets the transaxle spined shaft? 1 Quote Link to comment Share on other sites More sharing options...
Ibreakstuff Posted July 27, 2014 Share Posted July 27, 2014 (edited) One other thing... Did you remember to re-install the roll pins where the DOJ meets the transaxle spined shaft? This. +1 Mr Miles Fox did a video on the front bearing/seals also. I recommend a press or the hot/cold trick, but to each his own: Edited July 27, 2014 by Ibreakstuff Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 28, 2014 Share Posted July 28, 2014 Well.....that's not the best way to install the seal.....it probably isn't seated all the way but htat won't cause a clunk. I am guessing that you've got a balljoint, tierod, or swaybar bushing knocking over bumps. 1 Quote Link to comment Share on other sites More sharing options...
rdweninger Posted July 28, 2014 Share Posted July 28, 2014 My front struts were shot. New KYB's fixed the clunking. Put new bearings in the strut mounts. Quote Link to comment Share on other sites More sharing options...
l75eya Posted July 28, 2014 Share Posted July 28, 2014 Did you install the convex washer and the cone washer correctly? The washer that goes over the cone washer doesn't get installed either way, there's a specific side to have "out". It should be marked if you look carefully.Also; Is your brake caliper loose perhaps?If you have car ramps, pull up on those and slide underneath and start grabbing things and trying to move them. You might get lucky and find something that has play in it that shouldn't Quote Link to comment Share on other sites More sharing options...
JuhaKankkunen Posted July 28, 2014 Share Posted July 28, 2014 Did you also change inside cv joint, I meant the ones that's go nearby the gearbox? As someone says, the noise could be the brake calipers too. Quote Link to comment Share on other sites More sharing options...
