Where can I find another wiring harness factory connector?
So I know when I use my high beams, the fuse block gets very hot. So hot in fact that it looks like at one point in time there may have been some melting involved. I pulled it aparat to get a closer look and this is what I found.
14582726020_da5d66360d_b.jpgUntitled by blue03wrx, on Flickr
14582964467_c6ac3e8d0a_b.jpgUntitled by blue03wrx, on Flickr
I bought brand new, correct fuses. I wire brushed the actual contacts on the fuse block, and tightened up the fingers that hold the actual fuses in place. Now that all of that has been cleaned up, I need to track down another connector to try to replace the partially melted one I've got. I already checked RockAuto and I can't seem to find anything. Does anyone have any locations that might have the connector I can buy?
Edited by spicypeanut
if its from a gen1 Legacy EJ22 HARNESS I MOST LIKELY HAVE ONE
Its from a 1978 Brat. Not sure what the Legacy EJ22 used, could you post a picture? If it might fit I'll take it.
I'm pretty sure he means Gen I as in 1972-79 cars.
I would be suprised if Subaru didn't use the same connectors across multiple models for years.
