bh3025 Posted July 29, 2014 Share Posted July 29, 2014 is there any way that I can use the airbag struts and put coilover springs in them. tear the bladder off, take the strut assembly apart and insert the coil over, put the strut together and mount it on my vehicle for a temporary fix? where the coilover will sit is in between two metal bushings upper and lower. I would just like some feed back on this idea since searching it on the interwebs isn't turning anything up. driving an 89 xt6, stock air ride suspension.. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted July 29, 2014 Share Posted July 29, 2014 I doubt the springs would stay in place. If you look at regular struts, the upper and lower perches are formed to hold the springs and evenly distribute the load on the coil. Without the formed sections, the springs would pop out. Search air suspension. I know there are several write ups on which GL struts will work direct bolt in from a PnP. Quote Link to comment Share on other sites More sharing options...
BlackBoot Posted July 29, 2014 Share Posted July 29, 2014 (edited) Here's the link to what you need to swap the suspension. http://subaruxt.com/faq/airstruts/ http://subaruxt.com/categories/howto/ Edited July 29, 2014 by BlackBoot Quote Link to comment Share on other sites More sharing options...
